Rattle/squeak from bed... 2014 SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by L33_0h, Mar 13, 2024.
  1. Mar 13, 2024 at 8:38 PM
    L33_0h
    L33_0h [OP] New Member
    Hey all,
    I just bought a 2014 Tundra SR5 and at slower speeds (~50mph and under, worse at the slowest speeds) there is a pretty mean rattle/squeak coming from the back. The dealership looked and couldn't find anything, so they suggested it might be the Snug Top. Took it to a canopy place and they said the canopy is fine. They suggested taking out the drop-in liner, which I did, but the sound persists. When I jump up and down on the rear bumper when it's parked, the noise doesn't happen at all. When driving, it happens even on the smallest bumps, such as normal cracks etc that any road would have. It starts once I get a little momentum, maybe 10-20 seconds after I start driving. I also checked all leaf springs and the bushings and spacers are all intact. They aren't even rusty at all. There also is nothing that I can see between the bed and cab.
    Any suggestions? This is pretty frustrating and annoying, if you can imagine!
    Thanks!
  2. Mar 13, 2024 at 9:54 PM
    Stevebaseball
    Stevebaseball New Member
    Arizona
    2008 Tundra crewmax
    3” lift- 35 x 12.50 on 18” custom rims
    Did you check the tailgate / tailgate latch?
    I have a 2008 Tundra (that’s right 16 years old) and I replaced the latch awhile back but it will squeak from time to time.
    Another thing to check is the spare tire- make sure it’s tight
    Just 2 suggestions
    Good luck
  3. Mar 14, 2024 at 4:28 AM
    Stock suspension? Is it a high pitch squeal or a creaking?
  4. Mar 14, 2024 at 4:35 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    P.O. replaced leaf spring bushings with polyurethane?
    My bed squeaked when a small rock got into bed's rigidity support structure at the bottom. Took a while to find it out.
  5. Mar 14, 2024 at 5:56 PM
    d33pt
    d33pt New Member
    Sit in the bed while it's being driven and see if you can located it better that way.
  6. Mar 15, 2024 at 5:24 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Make sure the box bolts are tight. It's pretty common on older Tundras and tightening the box bolts seems to solve it.
