Rattle noise while accelerating
Discussion in '2.5 Gen Tundras (2014-2021)' started by buckeyeinlv, Sep 25, 2018.
  1. Sep 25, 2018 at 10:07 AM
    buckeyeinlv
    buckeyeinlv [OP] International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    You know the “rattle” sound a Diesel engine makes on a regular basis? Well I’m getting a similar sound coming from the engine as I accelerate under low rpm. Especially when moving up a hill or something that stresses the engine a tad and right before the transmission would typically shift into a lower gear for more torque. Normal cruising, everything is normal. Hard acceleration is also normal. Just under subtle acceleration/gas pedal to maintain speed as I’m starting to move up a hill or after coasting in traffic. Any ideas?
  2. Sep 26, 2018 at 5:32 PM
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    Maybe engine knocking/detonation?
    MS22 likes this.
  3. Sep 26, 2018 at 5:40 PM
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    How many miles do you have? My old tundra with high mileage made a noise with similar description and it as the belt tensioner going bad. But it was over 200k miles
  4. Sep 26, 2018 at 7:23 PM
    buckeyeinlv
    Brandon
    Henderson, NV
    About 18500.
  5. Sep 26, 2018 at 7:24 PM
    buckeyeinlv
    Brandon
    Henderson, NV
    Mine is still under the available service included from Toyota. So whatever they use at the dealer.
  6. Oct 22, 2019 at 3:44 PM
    Cwag25
    Cwag25 New Member
    Cale
    2014 toyota tundra crew 4x4
    My 2014 is doing the exact same thing and sounds the same as you describe. Did you figure out what it was?
  7. Oct 23, 2019 at 11:06 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I haven't noticed this on my Tundra, but I did have it on my 2016 Tacoma. It was a very brief detonation/knock when the engine hit the right load/rpm combo. I remember the Tacoma owners manual said it was normal. Maybe see if something similar is written in the Tundra manual?
    TTund16 likes this.
  8. Oct 23, 2019 at 5:46 PM
    tdn
    tdn New Member
    Michigan
    2021 CM 4x4
    My 01 was the same and easily solved. Worth a look
  9. Oct 23, 2019 at 5:48 PM
    TRD-tv
    TRD-tv Menace2Ohio
    Cleveland OH
    2012 MGM Tundra TRD
    i had a similar problem and i traced it down to my heat shields. ripped it off and fixed the problem. although ill get some hose clamps and put it back on before winter
  10. Oct 23, 2019 at 6:26 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    My '16 (22k miles) makes a knocking sound like that if I feed it regular fuel. It's worst at about 45 mph putzing along in 6th, then traffic speeds up a bit, give a little throttle and stumble ting ting before it decides to downshift. Eventually got to where if I have 87 in it I drive in S5 until I'm doing at least 50 mph so it doesn't do it so often. That means the mpg difference around town is high enough to make up half the cost difference of premium so it just drinks that now. It's never pinged on 93.
    Now that I think about it, the old 4.0L Tacoma had the same problem, pinging and eating spark plugs. I eventually I just quit feeding it the regular swill and all was right as rain. It was kind of expected for that motor though; the '05 4.0L (first year of it) said premium fuel recommended, then in '06 with exactly the same engine and tune said 87 octane required. On premium Toyota said it changed from 236hp > 239 hp, and 266 lb-ft > 278 lb-ft so it wasn't placebo when it ran better.
  11. Dec 2, 2019 at 11:37 AM
    Mbh1970a
    Mbh1970a New Member
    I have the exact same issue like a chattering noise like it is valves r a bearing. Every now and then on take off it will be quite loud for second but i can make it happen by just barley giving it gas especially up a hill. Going back to dealer today. First time they said it was normal last time they said my gas had to much ethanol in it. But it is a flex fuel motor ?
  12. Dec 15, 2019 at 9:03 PM
    buckeyeinlv
    Brandon
    Henderson, NV
    I was basically told I needed to start running 91 octane gas. While I feel this is a cop out on Toyota’s part, it does seem to fix the problem.
  13. Dec 16, 2019 at 2:39 AM
    Mbh1970a
    Mbh1970a New Member
    I think it has something to do with the flex fuel motor and the computer thinking it has more ethanol in gas than it really has. Any way i traded it in and got a 2020 crew max 4x4 and regular motor no flex fuel !!!
    DCGymRat303 and buckeyeinlv[OP] like this.
  14. Dec 16, 2019 at 8:12 AM
    Misfire
    Misfire New Member
    My old 2017 started making that noise around 50,000 miles. I had it to the dealer three times for examination but they never could give me a solid answer. They couldn’t find anything wrong and theorized it could be the alternator. I put another 20,000 miles on it and traded it in.
  15. Apr 2, 2020 at 6:51 PM
    AZTundra
    Paul
    Phoenix, AZ
    Did you ever figure out what the issue was?
  16. Apr 2, 2020 at 6:54 PM
    buckeyeinlv
    Brandon
    Henderson, NV
    Truck was knocking. Didn’t like 87 octane. Ran 91 and it stopped. If I went back to a lower octane gas it would start up again
    AZTundra[QUOTED] likes this.
  17. Apr 2, 2020 at 7:40 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    I’m using octane booster and premium gas. 1 tank to 1 bottle of Lucas octane booster mixture works, mine had an issue. Seams to have gone away. Mine is a flex fuel truck from Iowa,
