Rate this potential truck
Discussion in '1st Gen Tundras (2000-2006)' started by Kimosabe, Apr 23, 2024.
  1. Apr 23, 2024 at 12:02 PM
    Kimosabe
    Kimosabe [OP] Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I'm looking for group input on a potential next truck. Maintenance history is a little light. Recent invoice shows timing belt and water pump done last fall. It references a bad waterpump bearing. Not sure if that indicates overheating?
    Frame looks spotless and overall in good shape. Possible VC gaskets leaking in engine bay. Would appreciate input from fellow members.
  2. Apr 23, 2024 at 12:10 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Frame is clean. Brake fluid looks good. Power steering fluid looks dark. You'd think they would clean up the engine bay before posting pics. At least you can see that the battery is fairly new.
    Kimosabe[OP] likes this.
  3. Apr 23, 2024 at 12:12 PM
    Kimosabe
    Sun Valley, Idaho
    Can't tell if it looks like the coolant blew on the right side underneath the hood. Looks like something spewed. And not sure how concerned I should be about it.
    BroHon likes this.
  4. Apr 23, 2024 at 12:25 PM
    Looks like coolant blew everywhere under the hood. Closer inspection and owner explanation required. Would want to make sure it didn’t overheat.
  5. Apr 23, 2024 at 1:15 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Looks like the radiator cap popped.
  6. Apr 23, 2024 at 2:06 PM
    Kimosabe
    Sun Valley, Idaho
    Is there a way to confirm if the engine is damaged from overheating? I can only think of a pressure test to make sure head gasket is still solid.
  7. Apr 23, 2024 at 2:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Just assuming here, but if it had a bad WP bearing, and there's coolant all over the engine bay, something bad happened. What are they asking for it, and I'm guessing you're not close by it?
  8. Apr 23, 2024 at 2:14 PM
    shifty` In South Dakota Trouble ain't hard to find
    I definitely approve of the frame, 100%
    bmf4069 likes this.
  9. Apr 23, 2024 at 2:16 PM
    Kimosabe
    Sun Valley, Idaho
    That's where my skeptical mind is going. It's a Cali truck with under 200k miles and asking $11,500.
  10. Apr 23, 2024 at 2:19 PM
    Kimosabe
    Sun Valley, Idaho
    I'm growing more and more hesitant. Seems a little too good to be true. The invoice from the TB job states "Found bad water pump bearing."
  11. Apr 23, 2024 at 2:41 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Valve cover gasket looks interesting. Also that license plate sequence was only used in CA from 2010 to 2011, so that's not the original license plate.
  12. Apr 23, 2024 at 2:52 PM
    BriannaSTILLEN
    BriannaSTILLEN New Member
    Brianna
    The big spew mark underneath the hood is definitely something worth asking about.
  13. Apr 23, 2024 at 2:55 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    OHwendTrd and bmf4069 like this.
  14. Apr 23, 2024 at 3:04 PM
    That looks like it was leaking out of cylinder 8 spark plug tube gasket, solely.
    des2mtn[QUOTED] likes this.
  15. Apr 23, 2024 at 3:13 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Coolant reservoir looks empty, where in Cali is it?
  16. Apr 23, 2024 at 3:39 PM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    I have no idea what I am talking about, but I give it an 8.
  17. Apr 23, 2024 at 4:28 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    QUIT STEALING MY.......oh, that's your truck. Carry on.
  18. Apr 23, 2024 at 8:04 PM
    Kimosabe
    Sun Valley, Idaho
    Clovis area
  19. Apr 23, 2024 at 8:17 PM
    Kimosabe
    Sun Valley, Idaho
    Appreciate the insight from everyone. Helped to solidify my thinking and gonna pass on this one. I asked the seller to elaborate on the situation. He didn’t have much info to offer and it looks like another previous owner was the one who dealt with the TB/WP job and potential coolant situation. Makes it look like the current seller drove the truck for a bit, realized there was a problem and is trying to recover his cost.
  20. Apr 23, 2024 at 8:39 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    Looks pretty good. I'm about 10 mins away.
  21. Apr 23, 2024 at 8:58 PM
    Pnwtundy
    Pnwtundy New Member
    04 DC SR5 TRD, V8/4WD + LSD/Tow
    Frame looks cleaaaan. The headlights: "killlll meee"
  22. May 3, 2024 at 10:41 AM
    Kimosabe
    Sun Valley, Idaho
    I found another one. I'm leaning really hard towards getting it. Let me know your thoughts. The possible issues I see are the steering rack. What am I missing.
  23. May 3, 2024 at 10:53 AM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    I only see what looks to be light surface rust towards the rear. I would check that spare tire carrier cross piece. Probably only superficial. At first glance all looks clean. Winner :thumbsup:
    The Black Mamba Approved :thumbsup:
  24. May 3, 2024 at 10:56 AM
    Kimosabe
    Sun Valley, Idaho
    I probably won't be able to verify until I pick it up. It's a long way from here. I think it's worth the risk.
    OldGuy03 likes this.
  25. May 3, 2024 at 11:08 AM
    Pnwtundy
    Pnwtundy New Member
    Looks pretty good overall, some areas just look dirty/hard to tell if it's rusty. Looks like newer frontend components (cheap-o struts?)
    These areas look a little sus though.
    Love the color though, I think it's my favorite (and rare?)
    Kimosabe[OP] and Jack McCarthy like this.
  26. May 3, 2024 at 11:27 AM
    Kimosabe
    Sun Valley, Idaho
    The truck has been cleaned up some, cuz it was really dirty. There does seem to be some small surface rust spots, but not anything bad enough that looks deep or structurally damaging.
    OldGuy03 and Pnwtundy like this.
  27. May 3, 2024 at 4:49 PM
    Bank 1 exhaust is cut right behind the cat, or am I nuts? Frame looks solid, minimal work to do here. Scuff / wire brush it then hit it with satin black Rustoleum and you're golden.
    The Black Mamba likes this.
  28. May 3, 2024 at 5:31 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wonder how they managed to damage both sides of the bed in the same place. Overall it looks clean but I would definitely be under the truck with a flashlight inspecting the frame closer. The color matched mid rise topper is really nice.
    How many miles? Timing belt history? Any maintenance records?
    JasonC., Pnwtundy and Kimosabe[OP] like this.
  29. May 3, 2024 at 6:07 PM
    Kimosabe
    Sun Valley, Idaho
    You could be right. He did say he thought he heard an exhaust leak, but took it to dealer and they addressed it. Thats why we’re meeting at the dealership when I pick it up to address a couple things.
    Pnwtundy likes this.
  30. May 3, 2024 at 6:14 PM
    Kimosabe
    Sun Valley, Idaho
    The current owner has had it 9 years. It’s got 170k miles. I checked service history and carfax and back up what he says. He’s taken it to dealer for every maintenance. Timing belt done at the beginning of the year. Within the last 6/8 months he’s done rear axle seals, and wheel bearings.
    Ya the bed damage was odd to me too. I couldn’t think of any scenario where that could happen but not too worried about. Worst case is I can probably flip it right away. KBB has it priced a little higher
    JasonC. and FirstGenVol[QUOTED] like this.
