RAS HD or SD?
Discussion in 'Suspension' started by odin1701, Feb 25, 2022.
  1. Feb 25, 2022 at 8:03 AM
    odin1701
    odin1701 [OP] New Member
    2021 Tundra LTD TRD OR MGM
    Seems everyone loves their RAS who has them. We have a trailer that's probably around 6500 lbs loaded. Add in some wood, generator and various things in the bed for a camping trip and we'll probably be close to maxed out on payload for the truck. I do use a weight distribution hitch to help reduce tongue weight. Outside of this, I haul the occasional load but otherwise don't do a lot of towing/hauling.
    I'm not sure whether the RAS SD or HD would be the right choice. Anyone have thoughts? I don't necessarily want it to lift the back a ton as I have no other lift yet and won't for a while.
    AggiePhil likes this.
  2. Feb 25, 2022 at 8:07 AM
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    I learned on thing in life, go for more than you need on average and you have more longevity and flexibility if you need it. Id go HD with Tundra in general, especially with what you described. I set the RAS HD on 40% ( max setting ) and it lifted the back by 1" when empty. You can go with 25% setting and be around 0.5" lift. With my setting I noticed an Improvement in ride comfort when empty and when I tow trailer or have the bed full of tools and supplies the handling and comfort is greatly improved with little to no sag. Go HD, its worth the bit extra.
    TucsonTundra1794 and 2mchfun like this.
  3. Feb 25, 2022 at 8:15 AM
    2mchfun
    2nd vote for the HD. Been using mine for almost 1 year now. You don't need to set it real tight, so really lift can be minimized. Just get a airgap gap in the coils so it doesn't get loose during suspenion droop. Your gonna like it!
    Mobeyk likes this.
  4. Feb 25, 2022 at 8:34 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Get the HD. I did, it arrived Wednesday, I'll install it this weekend. You can always back the tension down if it's too much but you have the capacity in HD if you need it.
    TucsonTundra1794 likes this.
  5. Feb 26, 2022 at 3:57 PM
    r1-superstar
    DB
    UTAH
    I just finished the installation and it went pretty smooth. Here are some before and after pictures. I gained exactly one inch setting the HD springs at 25% (white disc 1mm). I have @BOSS4x4s shackles set at the highest setting (third hole 2" lift). If the RAS makes the rear sit too high for my liking, I will need to drop the shackles to the middle hole. I will post pictures later when I get the truck outside.
    2mchfun likes this.
  6. Feb 26, 2022 at 4:03 PM
    odin1701
    Yeah that will probably give me a bit much rake.
  7. Feb 28, 2022 at 2:16 PM
    r1-superstar
    DB
    UTAH
    Before and after...
    Sundog likes this.
