Rapid clicking noise
Discussion in 'General Tundra Discussion' started by Tx Supercharge Tundra, Aug 27, 2019.
  1. Aug 27, 2019 at 11:30 AM
    Tx Supercharge Tundra [OP] New Member
    Patrick
    01 Toyota Tundra 4.7 Supercharger
    New to the page, so I have an 01 toyota tundra that just recently started having trouble starting. It cranks but takes a while to get started. Once running there are no issues drives perfectly. When the key is in the on position I can hear my fuel pump kick on. But I hear a rapid clicking sound coming from a sensor that is located directly behind the engine block going into it. The wires from that sensor/solenoid run and connect to the fuel pressure regulator. I'm assuming the truck is struggling to get fuel to the injectors to start but once I crank it enough it gets enough fuel and then fires up and runs without issue. Any help would be greatly appreciated. Please and thank you.
