Rant: Remote start is useless! (maybe not after all)
Discussion in '2.5 Gen Tundras (2014-2021)' started by M3Tundra-JK, Dec 16, 2022.
  1. Dec 16, 2022 at 8:38 AM
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    Temp in the teens this morning. Remote started truck for about 10 minutes. Open door, of course I know it shuts the engine back off. Dumb! Leather seats, and steering wheel ice cold! How come if I leave the heat on full blast, and seat heaters on, turn off the truck, then start it again all those function kick in where they left off. But nooo, not if you remote start it, all stays off. Most useless remote start system I've ever owned!
    Edit: drink coffee first lol. I guess it does work....
    https://www.tundras.com/threads/rant-remote-start-is-useless.117344/#post-3018075
  2. Dec 16, 2022 at 8:44 AM
    JNJury978
    JNJury978 New Member
    2013 Toyota Tundra CrewMax Platinum 5.7L 4x4
    I'm not sure if all of the remote start systems work differently.
    Mine doesn't retain the settings I previously left either, but goes to an automatic "middle-of-the-road" setting, which IIRC is 71 degrees, half-way blasting, and blowing towards feet/defrosters. I'm guessing this is a safety precaution, but I don't see it being high risk considering the truck turns off after 10 minutes anyway.
    But yeah, it's almost worthless to me and I rarely ever use it.
  3. Dec 16, 2022 at 8:46 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    You need yourself a Viper Remote Start! Had one in my 2016 Tacoma for 6 years and now had on in my 2020 Tundra for a year and they are absolutely the best out there! Can start it from my watch or phone or keyfob! Doesn't shut off once you open the doors as well!
    TK1979, HulkSmurf14, WILLINH and 4 others like this.
  4. Dec 16, 2022 at 9:00 AM
    M3Tundra-JK
    Scott
    2005 GX470
    Will definitely look into that. Do you have the push start button in the 2020 also?
    WILLINH likes this.
  5. Dec 16, 2022 at 9:10 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I get that it is annoying feature and I see many many people complain about it…
    However, whether it was intentional or unintentional, it serves as an excellent system to protect your vehicle. Where I live the newer Toyotas that use that system have much lower stolen rates (when vehicle is left RUNNING with NON aftermarket auto starts) compared to especially Honda but most other manufacturers as well.
    There are advanced systems that can start and operate your vehicle without any key fob present but most criminals are not that sophisticated. Basically if they can jump in your running and drive off they will. Toyotas system doesn’t allow that.
    Personally I have found that the key fob can be much further away when running (yes the vehicle will start a bunch of high pitched audible warnings BUT it’s still operable for a time) vs when you want to physically start the vehicle. Key fob has to be much closer.
    VWTim likes this.
  6. Dec 16, 2022 at 9:22 AM
    M3Tundra-JK
    Scott
    2005 GX470
    I get safety aspect of it, kinda. Every remote start system I've used still requires the doors to be locked in order for the remote start to enable. So that should prevent anyone from just jumping in and trying to drive off
    sn_85 likes this.
  7. Dec 16, 2022 at 10:01 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I have the same one and its awesome !
    HulkSmurf14 and Moe2o4[QUOTED] like this.
  8. Dec 16, 2022 at 10:11 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    It's likely a trim level issue.
    My SR5 has a physical switch for the heated seats and a rotary dial for temp setting. They stay on whatever setting is last selected, next time you start the truck.
    1lowlife and M3Tundra-JK[OP] like this.
  9. Dec 16, 2022 at 10:14 AM
    M3Tundra-JK
    Scott
    2005 GX470
    To add to this, I've noticed that the Recirculating Air button always goes back to outside air after the vehicle is turned off. Which is another annoying thing to me. Idk if leaving the Tundra with the outside air flaps open makes the interior any colder than if it were shut, but sure seems like it does
  10. Dec 16, 2022 at 10:14 AM
    JNJury978
    I have a 2013 Platinum, so I'm thinking this feature got some upgrades over the years.
  11. Dec 16, 2022 at 10:24 AM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Same. On my 22 Ram 2500 when I start the vehicle remotely I have to unlock the car via the fob to get in and then if I want to put it into a drive mode the fob has to be within the cab. If someone wants to and can steal the car after all that then well they've done their homework and are likely professionals at it. Not much I can do to prevent it that at that point.
  12. Dec 16, 2022 at 10:35 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Yeah I agree. With all the electrical engineers the world has Toyota makes it so the truck shuts off when you touch the handle.
    Im not buying any safety security nonsense. We have the technology, and skills period.
  13. Dec 16, 2022 at 10:50 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    It's odd that your climate settings change. When I remote start my truck, the seat heaters go back to whatever setting I had them on when I turned the truck off. I make sure they are on when I shut it down the night before so the seats are warm in the morning when I remote start it. Same with my climate settings, which I leave on 70 degrees and Auto mode.
  14. Dec 16, 2022 at 10:52 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Sadly it has nothing to do with electrical engineers; all to do with lawyers.
    It only takes one person absentmindedly getting into a started vehicle, put it in gear and run over someone, and then claim they did not realize the engine was running. Sad but true reality.
  15. Dec 16, 2022 at 11:22 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    No push to start, I have an SR5 so I have a key. But you can install a Viper system with push to start or key!
    M3Tundra-JK[OP] likes this.
  16. Dec 16, 2022 at 11:35 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Or lock your grandkids in the car, windows rolled up after the remote start finished running and spare key locked in cab (not me). ;)
  17. Dec 16, 2022 at 12:37 PM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    I consider getting off my dead a$$ & walking out to start my truck part of my workout program. That way I don’t miss remote start since I am getting my steps in.
    Boerseun and Piney like this.
  18. Dec 16, 2022 at 1:00 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    We’ll have to agree to disagree, lol. We still have a vehicle that starts remotely and any safety feature could fail and cause an accident. Other vehicle manufacturers or add on remote companies have no issues with this.
    Boerseun[QUOTED] likes this.
  19. Dec 16, 2022 at 1:02 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Truck setting rarely change year round. 68 degrees auto and the heated seat on high. Literally never have to touch it. If the ac wants to come on or the recirculate mode I just let it do it’s thing. That’s why I got the limited trim
    TK1979 and JDR76[QUOTED] like this.
  20. Dec 16, 2022 at 1:13 PM
    Piney
    Piney New Member
    South Jersey Pine Barrens
    2020 MGM TRD Pro
    Same with my 20 Pro. If I know it's going to be cold the next morning and I'm going to remote start, I will set up my truck to full blast defrost heat and put my seat heaters on high before I shut down. It saves the settings.
    The 10 minute run is enough to get it warmed up a bit and get the windshield clear of frost. A couple minutes of driving later, it's nice and toasty.
  21. Dec 16, 2022 at 2:02 PM
    clarkritchie
    clarkritchie New Member
    This. You simply have to remember to turn on your defrost, seat heater, etc. when you park it the night before. If you leave it all as you want it in the morning, it works as advertised. If not, then you're out of luck. I'm not disagreeing that it would be 1,000x better if the truck knew to turn on the defrost, or at least provided the ability to do that remotely, but the system just isn't that sophisticated. Put a sticky on the dash if you have to. It sort of blows to remote start and still have to scrape ice off the windshield.
    Question -- Do the seat heaters function if no one is in the seat? In other words, do they have any sensors, perhaps by occupant weight, to detect that the seat is unoccupied and therefore, the heated seat is not actually on despite it being turned on?
    Been remote starting here for the last 6 weeks. I usually remember to leave my seat heater on but the seat itself is usually still quite cold when I get in. But I've attributed that to the 10°F air inside the vehicle, and less to any problems with the seat heater, which works fine when there's a butt in the seat.
  22. Dec 16, 2022 at 2:10 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Ok y'all, I guess I was just extra cranky this morning lol
    Tested, I was wrong and I just need to make sure everything is set to max when I turn it off!
    Took pic from outside truck, after remote starting it
    TK1979, BravoDeltaRomeo and Piney like this.
  23. Dec 16, 2022 at 2:13 PM
    JDR76
    JDR76 New Member
    WA
    The seat heaters are not tied to any occupant sensors in the seats. My seat is usually nice and warm after a few minutes with remote start, but I'm working with 30-40 degrees ambient to start with, so not too bad.
  24. Dec 16, 2022 at 2:23 PM
    clarkritchie
    My 21 Limited does not greet me with HI like that. Usually, it's more of a FU for leaving it outside in 10°F weather.
    batman900, TK1979 and M3Tundra-JK[OP] like this.
  25. Dec 16, 2022 at 2:26 PM
    M3Tundra-JK
    Scott
    2005 GX470
    TK1979 likes this.
  26. Dec 16, 2022 at 3:25 PM
    Piney
    Piney New Member
    2020 MGM TRD Pro
    My seat heaters also take a while to get warm.
  27. Dec 30, 2022 at 8:41 AM
    splitfuse
    splitfuse Dr. Tundra
    AB-CAN
    2020 Cement Tundra Crew TRD
    I can just see the cross-examination now, "Am I correct in understanding that you consciously put the vehicle in drive but were surprised when it advanced forward?" :rofl: "I see here that you completed a driver training course and hold a valid drivers license, could you please explain to the jury, the difference between park and drive?" :rofl:The lawyers would have a hay day with this
    TK1979 likes this.
  28. Dec 30, 2022 at 8:55 AM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Is yours a DIY heated seats? I'm still thinking of adding heated seats for mine and wiring mine to a always hot 12 volt access.
  29. Dec 30, 2022 at 9:06 AM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    The one that annoys me is that the window/mirror heater does not turn on even if left on when shutting off. It would be nice if it could be programmed that if the vehicle is remote started, turn on the window/mirror defrost. Or since there's an abundance of technology in the vehicle, IF temperature < 35 & Start = Remote THEN turn on with remote start.
    TK1979, M3Tundra-JK[OP] and splitfuse like this.
  30. Dec 30, 2022 at 9:13 AM
    JDR76
    JDR76 New Member
    WA
    Mine actually does that. The other morning I remote started the Tundra. Because of this thread, I peered in the window before unlocking, to view the climate settings. I had left it in auto mode. To my surprise, the truck had turned on the mirror heat/rear defogger and switched the main climate control from auto to front/side defrost. When I got in and restarted it, it went back to auto mode.
    Ambient temp was 16 degrees when it did this.
