Range says “refuel” but I have fuel. Any help?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stocky Balboa, Jan 21, 2020.
  1. Jan 21, 2020 at 12:43 PM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Disconnected the negative terminal, reconnected and then this happened. I drove about 7 miles and no change.
    any ideas on how to fix it? Is there a reset?
    ‘18
    thanks
  2. Jan 21, 2020 at 12:46 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    It'll reset after a drive or two, no worries.
    Mine did it when I did the interior lights and again when I did the LP lights, as I removed the negative terminal when working on them.
    It takes a few miles/KMS to know your driving pattern and gauge how many miles until empty. I think mine took up to 20km or 15miles and then it came back
  3. Jan 21, 2020 at 12:52 PM
    Stocky Balboa
    OC , CA
    appreciate the response. Thanks!
  4. Jan 21, 2020 at 1:34 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    This ^^^
    On my second on third fill-up I disconnected the battery right before filling up. When I started the truck after filling up, the range said "952miles to empty" I just laughed as it stayed high until I got to about a half tank, then it plummeted fast and wanted me to refuel way before empty... I filled up, then disconnected the battery for a reset, then all was good after that.
    Stocky Balboa[OP] likes this.
  5. Jan 21, 2020 at 1:34 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Mine did the same when they did the PCS recalibration. I was hesitant at first and even drove around the block to see if it reset. Talked to the master tech and he confirmed that it takes a few miles to reset. Sure enough, by the time I hit the freeway it was back to normal.
  6. Jan 21, 2020 at 1:52 PM
    Stocky Balboa
    OC , CA
    Thanks everyone. All good now. It reset after a few more miles.
    cheers.
  7. Oct 31, 2023 at 3:56 PM
    Roughneck18
    Roughneck18 New Member
    Louie
    2019 white Tundra Trd off-road
    Trd exhaust
    I have same issue but I didn’t disconnect anything. Was low on fuel, put about 1/4 tank in and still says refuel with no range miles indicated. Drove a few miles, still no change. Any solutions ?
  8. Dec 8, 2023 at 10:16 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Hi, I know it's been a couple months since your message but did the message ever go away for you? I'm having that issue now as well and do see that everyone says not to worry so I guess I will just wait and see.
  9. Dec 9, 2023 at 6:19 AM
    Roughneck18
    Louie
    Trd exhaust
    Yea, I disconnected the battery, then connected again. It never came back. I’m just curious why i got that to begin with. Maybe a battery issue ? I got 4 yrs with same battery.
    TacomaTRD4x402 likes this.
  10. Dec 9, 2023 at 8:52 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    4 years, time for a new battery. Generally they last 3-4 years, less if you live in an area with temp extremes.
  11. Dec 9, 2023 at 9:15 AM
    TacomaTRD4x402
    Southern California
    Okay cool! Thank you. I'll give that a try if mine is staying on.
