Random misfire on even # cylinders
Discussion in '1st Gen Tundras (2000-2006)' started by Hillbillydragyn, May 24, 2021.
  1. May 24, 2021 at 1:17 PM
    Hillbillydragyn
    Hillbillydragyn [OP] New Member
    2002 white tundra TRD sr5
    I've had a 3in lift and larger tires and a new stereo thats it
    I was coming home the other night and suddenly lost power I stopped and looked under the hood couldn't find anything obvious this went on for about 15,20 miles then she picked back up power when I got home the next day I got a thing from online to read codes and got po300,po302,po304,po306,po308 which is random misfire on left side of motor I've switched coil packs ,plugs,inspected and cleaned the crank sensor checked vacum lines I'm out of ideas ,why only the left side I'm so puzzled
  2. May 24, 2021 at 2:14 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Possible water contamination in the gas if nothing else. Keep a bottle of dry gas available in case it happens again and gets worse.
  3. May 24, 2021 at 3:00 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If it was bad gas I would assume it would hit both sides with random misfires. My guess would be spark plugs or maybe some electrical damage in wiring.. one more thing, maybe a warped head or head gasket allowing coolant ingestion..
  4. May 24, 2021 at 7:17 PM
    Could be cam related?
  5. May 24, 2021 at 7:21 PM
    Hillbillydragyn
  6. May 24, 2021 at 7:40 PM
    Cam position sensor on that bank of cylinders? Cam out of time on that bank of cylinders?
  7. May 24, 2021 at 9:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You may have a cylinder that’s misfiring and dragging the others on that bank down with it. Compression test before going too far on anything else just to rule out compression loss (which I doubt) you may have an injector issue
  8. May 24, 2021 at 9:16 PM
    empty_lord
    05 rollover special
    There is only one cam sensor on the 4.7 if I remember correctly. On the driver side cam
  9. May 24, 2021 at 10:44 PM
    Tundrajoe
    Tundrajoe New Member
    Joe
    2014 crewmax super white
    Bilstein 5100s cooper at3 xlts, tint, full custom exhaust, methods
    More than likely a stuck o2 sensor, if stuck rich it will lean the affected cylinders. Vice versa if stuck lean. O2 sensors are on each bank, therefore causing all even cylinders to show misfires.
  10. May 25, 2021 at 2:23 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Could be getting ready to toss the timing belt...when was it last changed?
    Tundratoofun likes this.
