Random idle studder and engine die
Discussion in 'Performance and Tuning' started by Mountun Goat, Aug 27, 2020.
  1. Aug 27, 2020 at 8:15 AM
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Hey team.
    My truck has been stumbling during idling randomly last few months. Couple times it’s died during idling- restart without issue or throwing any codes.
    This seems awfully similar to when our Sienna’s fuel pump quit.
    First off, does the 5.7 have a serviceable fuel filter?
    Anyone else have this issue and figure the fix?
    Thanks in advance.
    Pic cause pics.
  2. Aug 27, 2020 at 8:47 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    From just reading the thread title my first thought was "fuel delivery." I'm embarrassed to say I don't know where the fuel filter is but I'd guess it's above the tank.
    Mountun Goat[OP] likes this.
  3. Aug 27, 2020 at 8:59 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  4. Aug 27, 2020 at 10:53 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks for this info. But damn I guess the pump is the issue. I’ve tried pretty concentrated fuel system cleaner to see if it helped. Not so much.
  5. Aug 27, 2020 at 10:54 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Fuel delivery I’m sure as well. Seems like fuel filters are rare on newer vehicles. Don’t be embarrassed haha
    831Tun[QUOTED] likes this.
  6. Aug 27, 2020 at 10:54 AM
    Squatting Pigeon
    Holden
    North Texas
    Could be a loose connection. Have you unplugged it and checked everything? Maybe spray a little connector cleaner in there?
  7. Aug 27, 2020 at 10:55 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Good call. I’ll double check wiring first. :hattip:
  8. Aug 27, 2020 at 10:56 AM
    Squatting Pigeon
    Holden
    North Texas
    Since it’s intermittent I’m hoping it’s just a touchy connection :fingerscrossed:
  9. Aug 27, 2020 at 11:04 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    URD makes fuel pump kits if you get a new pump, they're a lot cheaper than stock according to a dude I was talking to the other day. It's pretty easy to swap the pump if you end up doing that. I can't say I remember seeing a filter near the tank, and definitely don't remember one inside the tank besides the little fuel sock, though it was awhile ago I upgraded my pump.
    831Tun and Mountun Goat[OP] like this.
  10. Aug 27, 2020 at 1:15 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Rad, thanks for this info dude. Any performance gain/loss with the urd?
  11. Aug 27, 2020 at 1:46 PM
    snivilous
    SW UT
    Did it when I did the blower, so can't say. Don't see why the pump alone would add anything unless you were running lean. I got the aeromotive 340 and no issues at all, food for thought.
  12. Aug 27, 2020 at 1:57 PM
    @Roman can you shed any light on the fuel filter and pump questions here?
    I hope Holden is right and it's just a wonky electrical connection, but the symptoms definitely sound like fuel delivery issues.
  13. Aug 28, 2020 at 1:25 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’ll have to have a look this weekend.
  14. Aug 28, 2020 at 6:58 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Could be any number of issues. I can't speculate.
    As far as the filter, it is in the canister in the tank with the fuel pump. The filter itself is not serviceable. You'll have to replace the canister.
  15. Aug 28, 2020 at 9:21 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks for the info @Roman
    Roman[QUOTED] likes this.
  16. Aug 28, 2020 at 4:04 PM
    I was just after your parts knowledge. :p
  17. Aug 28, 2020 at 4:09 PM
    TemujinNomad
    TemujinNomad New Member
    Doesn’t hurt to run some seaform. Had similar idling issues with 2uzfe, ran a couple cans through and so far so good.
  18. Aug 28, 2020 at 4:28 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Cool thanks
  19. Aug 31, 2020 at 8:42 AM
    Roman
    Roman
    Franklin, TN
    I feel so used and dirty now...............
    I like it. :D
