Random hood separation
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra_Dawg, May 17, 2019.
  1. May 17, 2019 at 10:17 AM
    Tundra_Dawg
    Tundra_Dawg [OP] Boss Moss
    Arizona
    2017 MGM Platinum
    PPE headers, TRD exhaust, ICON 3" lift, Raceline wheels, Powertrax Tonneau cover; 2019 TRD Pro headlights and fogs; TRD pro grille; Victory 4x4 sliders.
    I did some offroading yesterday without any issues. Ran several errands in the Tundra afterward. This morning, opened up the garage door to take my son to school, and I see this in the photo. WTH?? No front end damage, everything looks normal under the hood. I was able to pop it back in with some muscle at the top, and it looks fine now.
    Can anyone explain this? This is my 2nd Tundra and I've never seen a piece randomly separate. I can't even imagine how. I could see the tabs underneath that were not in the proper openings. I should also mention that I have never removed this piece (nor do I even know how). Also, it was not touched by the garage door - there is about 8 inches of clearance, and I was standing next to the truck as the garage door opened.
  2. May 17, 2019 at 10:22 AM
    Looks like it’s your grill that is folding
  3. May 17, 2019 at 10:23 AM
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Only thing I can think of, but you said you had plenty of room, is the metal bar that goes horizontally across your garage door. To me the bar would hit your truck exactly where you have the separation and push it down.
  4. May 17, 2019 at 10:25 AM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    15whtrd, Tundra_Dawg[OP] and TheBeast like this.
  5. May 17, 2019 at 10:48 AM
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
    Thanks for the link. I could see the tabs were out of the "sockets" or whatever you call them, and I was able to force them back in and now it looks perfect again. I couldn't see anything broken, but I couldn't see further in. The bizarre part of it is that it happened while parked in my garage, not while driving. I park in the same spot every day - never contact with my garage door.
    Ostrich[QUOTED] likes this.
  6. May 17, 2019 at 10:49 AM
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
    The grille looked perfect - except for a ton of bugs. I took a photo of it as well, though not posted.
    4x4_Angel likes this.
  7. May 17, 2019 at 10:52 AM
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Was it particularly hot when this happened. Possible that plastic and metal stretch or shrink differently? Maybe one cooled off faster than the other causing misalignment?
  8. May 17, 2019 at 1:24 PM
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
    Well, this is Arizona where it's always hot. It did cool off from about 90 to 70 overnight, but not unusual for AZ.
  9. May 17, 2019 at 1:34 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  10. May 17, 2019 at 2:05 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    :eek::eek2:
  11. May 17, 2019 at 2:16 PM
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
    Gremlins at the very least.
  12. May 17, 2019 at 2:21 PM
    Squatting Pigeon
    Holden
    North Texas
    Did you feed them after midnight? :facepalm:
  13. May 17, 2019 at 2:23 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Or get them wet?
  14. May 17, 2019 at 2:50 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Looks to me like the hood bulge part of the grille warped. Shouldn't have that peak in the center.
    Black Wolf likes this.
  15. May 17, 2019 at 2:59 PM
    Damn Russians.....
  16. May 17, 2019 at 6:38 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    When you get out of the truck and walk into your house, do you walk around the front of the truck?
    Is it possible someone was trying to slide between the inside of the door and the truck, and pressed up hard against the bulge pushing it out of position?
  17. May 17, 2019 at 8:29 PM
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
    It was deformed while out of position - but once i snapped it back into place it looks normal again.
  18. May 17, 2019 at 8:34 PM
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
    I back it up within 1 inch of the wall in the rear, so yes, I walk around the front of the truck. But I walk around and then close my garage door, because there is only about 8 inches of space. Nowhere to go in the garage on the driver's side of my truck unless you are getting in the driver's seat - therefore the garage door is opened beforehand (and nobody drives the truck but me, plus my son is 8 and my wife could blow away in a strong wind - in other words, neither one would have the body weight to pop that bulge out). But thanks for brainstorming ideas for me. I simply have no clue at this point. It is bizarre!
  19. Oct 4, 2019 at 9:44 PM
    Tundra_Dawg
    Arizona
    2017 MGM Platinum
    I have figured this out, but unsure how to prevent it. It happens when highway driving at 80 MPH+ when there is a strong crosswind - particularly I have seen it pop up with the air blast while passing a semi. Since I do a lot of highway driving, It has happened now about a dozen times. I can always snap it back in with some mild force.
    JimboSlice413 likes this.
