Ranch Hand legacy grill guard
Discussion in '2.5 Gen Tundras (2014-2021)' started by ZACH Gorman, May 1, 2017.
  1. May 1, 2017 at 9:35 AM
    ZACH Gorman
    ZACH Gorman [OP] New Member
    2015 SR5 4x4
    I was wondering how many of you gents and ladies have one of these installed on your truck. I had one installed the other day and notice a lot of bounce or flex when travelling down road. The grill is not loose...I rechecked bolts with impact gun. So I contacted ranch hand and they said with Tundra that is fairly normal. That and that the bolts losen up. Now if that is the case why haven't they tried to correct problem?
  2. May 1, 2017 at 1:56 PM
    ubserved
    ubserved New Member
    Michael
    2017 Toytota Tundra Platinum Crewmax
    Grillguard, front LED light bar, Leer Tonneau cover, rear LED bars
    I just bought a 2017 Tundra and on my previous truck, I had a Go Rhino Wranglerguard grill bars on it. When I got mu current truck I went to get the same brand and model of bars on it for this truck. It was back ordered and wasn't available for weeks and the shop suggested a set of bars from Westin that looked nearly identical and they could have them there in like 2-3 days for the same price. So I went with that option and they arrived and were installed and I had the same problem as you. They shaked, rattled and rolled. There was like about an inch of horizontal movement so I had them removed. I wasn't happy, the shop called the manufacturer and their 'tech support' was useless. So we ordered my Go Rhino bars and they are on the truck now and are absolutely solid. I think what the difference was the mounting brackets from Go Rhino are huge and solid and those bars don't move at all. The ones from Westin and I am assuming it's a similar issue to the Ranch Hand is that they are not as solid and like with anything, if your foundation isn't solid, nothing past that will be. Hope that helps. I have a picture up here with the bars installed on the truck if you want to see.
  3. May 1, 2017 at 2:37 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Pics??? Where?
  4. May 1, 2017 at 2:41 PM
    ubserved
    ubserved New Member
    Michael
  5. May 1, 2017 at 3:04 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    zcarpenter92 likes this.
  6. May 1, 2017 at 3:05 PM
    csuviper
    Broomfield, CO
    If the bolts are loosening up on you then you should add some loctite.
  7. May 1, 2017 at 3:19 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Is it heavy? Could the weight just be letting the truck bounce a smidge over normal that you notice it.
  8. May 1, 2017 at 3:28 PM
    ubserved
    ubserved New Member
    Michael
    The issue I had with the first set of bars was that their mounting brackets were absolute garbage. I was able to compare them side by side with the Go Rhino brackets. The GO Rhino brackets were twice as thick and absolutely solid. They have been on the truck for several weeks and haven't moved a fraction of an inch. Just my 2 cents worth. If you want bars and want them solid...get the Go Rhino Wranglerguards.
  9. May 1, 2017 at 6:07 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    It's only like 115 lbs or so.
  10. May 1, 2017 at 6:31 PM
    Cut mesh screen out
  11. May 1, 2017 at 9:16 PM
    ubserved
    ubserved New Member
    Michael
    I actually like the mesh, it's looks great but also keeps anything from going through your radiator....like protesters for example. :)
    Tacogrande likes this.
  12. May 2, 2017 at 5:19 AM
    I haven't had any bolts loosen up on my Ranch Hand. I totally over torqued them with a breaker bar. I have a decent OME setup that has worked quite well handling the extra weight .
  13. May 12, 2017 at 10:40 AM
    ZACH Gorman
    2015 SR5 4x4
    I haven't had them losen up on me that is what ranch hand said they have had complains about. However I do think that it has to do with the mounts and how low they are on the truck. I have noticed othe tundras on the road that have ranch hands have the same bounce
  14. May 12, 2017 at 1:10 PM
    ubserved
    ubserved New Member
    Michael
    I still suggest the GoRhino Wranglerguard. The mounts are solid and there is no movement whatsoever.
  15. Sep 14, 2017 at 4:33 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Like it with out the mesh too, how is it holding up? Rust?
  16. Sep 15, 2017 at 10:04 AM
    SleeperTRDPro
    SleeperTRDPro The small package good things come in
    Austin, Texas
    I have one on mine. Does not flex or bounce at all unless I'm off road.
  17. Sep 15, 2017 at 11:14 AM
    No rust...i grinded down smooth then 3 good coats primer then 3 coats paint
  18. Sep 15, 2017 at 12:54 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    How big of a PITA is it for you to pull your grill off with that ranch hand on?
  19. Sep 15, 2017 at 1:00 PM
    I bought grille off offerup.com for 175$...I cut screen out before putting on...then I didn't like the shiny black look..I took off n painted flat black...u need an extra pair of hands to help..once the brackets that are bolted to tow hooks those can stay.. it's the 4 bolts 2 each side that hold grille on...but yeah call a buddy tell him u got pizza n beer for him
    BOBONTUESDAY[QUOTED] likes this.
