Rail Dust??
Discussion in 'Detailing' started by Theslickhick, May 5, 2017.
  1. May 5, 2017 at 9:58 AM
    Theslickhick
    Theslickhick [OP] New Member
    I was washing my truck a weekend ago, and noticed many spots that wouldn't wash off, or buff off.
    A friend of mine who was in auto body tells me its something called rail dust? And is the result of when the vehicles are shipped on trains across the country, little sparks of metal from the rails flying up and embedding in the paint.
    He tells me given the truck is just over a year old that the warranty should cover this and to take it to the dealer.
    He seems to think its pretty bad as its all over the entire sides of the truck- which is a white 2016 crewmax.
    Has anyone else found this on their truck or taken it to a dealer before??
  2. May 5, 2017 at 10:05 AM
    blizz86
    blizz86 New Member
    Rail dust, industrial fallout, paint contamination from brake dust.. it happens. Try Carpro Iron X, and see if it comes out. It should if its on the outside of the clear coat. If its under the clear coat, the dealer MIGHT accept it back. Most dealerships won't take anything back unless its a clear paint defect or rusting through.
  3. May 5, 2017 at 10:29 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    My 04 GTO was subject to this. Meguiars clay bar did the trick. Followed that up with 4 coats of Zaino. That car was a red mirror.
    ColoradoTJ and SouthBoundSteve like this.
  4. May 5, 2017 at 10:38 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    SouthBoundSteve likes this.
  5. May 5, 2017 at 1:32 PM
  6. May 5, 2017 at 1:55 PM
    AxelsHumanDad
    2015 CM Platinum
    The Iron X that I used on my other truck cleaned it up nicely. But since it comes back yearly leads me to believe it's the road brine. You should see the 2013 white work van I drive that has never been touched. It's covered with brown acne.
  7. May 5, 2017 at 1:58 PM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    THIS^^^^
    I had this on my white 2010 as soon as I brought it home I saw it all.
    clay for me as well and some elbow grease rectified...
    EagleSteve is the man in this area so yah....
  8. May 5, 2017 at 2:29 PM
    AxelsHumanDad
    2015 CM Platinum
    Witaj Polskiego sąsiada! Jestem Słowacki. :wave:
  9. May 5, 2017 at 3:22 PM
    TheBeast The Beach
    clay bar
  10. May 5, 2017 at 3:23 PM
    I like a good whiskey as well.
    Not sure what you mean about panties Steve.
  11. May 5, 2017 at 4:45 PM
    Oh, I'm Scandinavian sir.
  12. May 5, 2017 at 4:49 PM
    I waxed mine for 2 hours. Got them all off...you just really have to dig into it, and it'll come off.
    ColoradoTJ likes this.
