Rago Dash Plate
Discussion in '2.5 Gen Tundras (2014-2021)' started by ProtoJ, Jun 29, 2020.
  1. Jun 29, 2020 at 7:01 PM
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    I don’t know what this thing weighs......buts it’s heavy! Pretty easy install. I recommend!
  2. Jun 29, 2020 at 7:25 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I've been thinking about getting one of these for a while.
    ragofabrication likes this.
  3. Jul 30, 2020 at 6:23 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I need some mount options. I just ordered the Rago this morning and I am completely lost at what mount/arm I should get for my phone. The 67d stuff looks great but it’s pricey.
    What other phone mount options for the Rago are out there? I just want to mount my phone and if the magnetic ones work good, that would be my first choice.
    thanks in advance!
  4. Jul 31, 2020 at 7:42 AM
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    Ram ball, ram arm, tachform motorcycle mount.
  5. Aug 9, 2020 at 1:17 PM
    CaptainGrumpus
    Maine
    Where did you get the stainless steel inserts? Looks good.
  6. Aug 9, 2020 at 1:18 PM
    CaptainGrumpus
    Maine
    Just put mine in. Waiting on 67d to arrive tomorrow to finish it up. I added some socket head cap screws to the top to see how it would look with the holes filled. Not sure if I like it though.
    Wallygator and TylerDurden311 like this.
  7. Aug 9, 2020 at 2:58 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Good call on the 67D. I would have not wasted my time and money on the RAM had I known it would end up being trash.
  8. Aug 9, 2020 at 3:49 PM
    CaptainGrumpus
    Maine
    I ordered the 67d arm for Ram mounts by accident so I sent that back and have the correct one coming for the 67d magnetic mount. It seems really strong so I’m hoping my phone will stay put. If it doesn’t, I’ll order the cell holder they sell when they come back in stock.
  9. Oct 24, 2020 at 8:55 PM
    ak49
    ak49 New Member
    Alaska
    2020 White Tundra TRD Pro CrewMax
    Has anyone with the Rago dash plate experienced vibration? My dash has a very subtle vibration that I never noticed until I attached a medium length RAM arm and my phone to the plate. I mounted the ball to the second row of threaded holes from the edge of the dash. I've also tried using a short arm and it only mildly reduces the shaking. It shakes at speeds over 20MPH and is almost unbearable to look at for anything. I haven't read of anyone complaining about this. Is there something that can be done to help reduce the vibration of the dash mount or plate itself?
    AggiePhil likes this.
  10. Oct 24, 2020 at 9:00 PM
    GravityGear
    Aurora, CO
    Do you have a reinforcing plate on the underside of the dash?
    The plate adds lots of structural rigidity and you'll get less flexing. I have the ICS with the reinforcing plate and I get no dash flex. The only shaking I get is from the shitty RAM ball. You will need to make one or buy the ICS and modify it to fit the Rago. The spot these things screw down on is pretty thin.
  11. Oct 24, 2020 at 9:01 PM
    ProtoJ
    I just have 2 phones mounted to mine.....but no. Almost no vibration for me.
  12. Oct 24, 2020 at 11:09 PM
    ak49
    ak49 New Member
    Alaska
    I did use some extra large fender washers on the underside to help distribute the load, but I may have to look into the ICS underside plate.
    CaptainGrumpus likes this.
  13. Oct 24, 2020 at 11:16 PM
    ak49
    ak49 New Member
    Alaska
    What size arm are you using and what mounting location are you using? Here is a not so great picture of my mount locations. (Sorry, it's all I had on hand.)
    bulldog93 and Wallygator like this.
  14. Oct 24, 2020 at 11:20 PM
    ak49
    ak49 New Member
    Alaska
    Oops. I didn't notice that you were the OP. Looks like we're using the same mounting locations and arm size. The only difference is my arms are horizontal. Maybe I'll try a more vertical position like yours.
  15. Oct 25, 2020 at 3:31 AM
    CaptainGrumpus
    Maine
    I’ve had good luck with my 67 Designs arm. Very little vibration with the medium length arm and the Magmount G2 holding my iPhone XS Max
  16. Oct 25, 2020 at 6:43 AM
    ProtoJ
    I also purchased the ICS backing plate but didn’t install it. It looked like it would need new holes drilled in it and I didn’t have any drill bits on hand that would have drilled through metal that thick.....so I skipped for now. If I ever put an iPad on the Rago dash plate I’d consider it.
  17. Oct 25, 2020 at 7:22 AM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    I just put wider washers when I mounted my plate. No vibration. I run a GoPro and iPad mini on mine.
  18. Oct 25, 2020 at 8:17 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Ordered mine...getting a Galaxy Tab A mount with a Ram Mount. I've used Ram Mounts on my boat and they're not horrible but you do need to replace the balls every once in a while. They don't do UV and heat well.
    Figured this would be a good winter job. I have a Dash pad/phone cradle but the phone overheats if I leave it there while traveling. This will solve that and give me a big screen for maps without a radio swap.
  19. Oct 25, 2020 at 10:23 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I have the ICS with the underdash support plate. It is rock solid.
  20. Oct 25, 2020 at 10:42 AM
    Saab95v6
    Saab95v6 New Member
    I just received my Rago dash mount , I also ordered the ICS plate to mount on the underside for stability, I will have to drill some holes . Hopefully I can install it right so no vibrations down the road
    Zilla18 and Wallygator like this.
  21. Oct 25, 2020 at 11:00 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    I also use the ICS with the plate underneath it. Love it so far.
    Gabrielo93 and Wallygator like this.
  22. Oct 31, 2020 at 12:03 PM
    salmonator
    Tigard, OR
    Harbor freight $4. Mild steel is pretty easy to drill through.
    bulldog93, AggiePhil and Saab95v6 like this.
  23. Nov 16, 2020 at 3:12 PM
    TSands83
    TSands83 USAF Jet Engine Mechanic
    OKC, OK
    2015 Attitude Black Tundra Platinum CM 4x4
    Black TRD Pro headlights, iHacker LED Plug N Play harness, black LED fog lights, TRD Pro grille, TRD skid plate, TRD front and rear sway bars, TRD Pro Fox shocks, TRD intake, TRD dual exhaust, Lexus/Toyota aluminum oil filter cap, Stahlbus oil drain valve, black Fuel Offroad Pump 20x9+20 wheels, color matched mirror caps and door handles, stubby antenna, black tube steps, driver side assist handle, Rago dash plate with ICS backing plate, SR black interior door handles, SR black dash center panel, Tacoma/4Runner left and SR right black steering wheel switches, black steering wheel emblem, black TRD shift knob, AJT Designs shifter and cup holder bezels and HVAC control knobs, Husky floor mats, Trail Edition bed storage boxes, bed LED strip lighting, bed mat, Charvonia Design Billet Tie-down Anchors, 38 gallon fuel tank, RCI fuel tank skid plate, AVS window deflectors/visors, Recon taillights, Recon smoked 3rd brake light, GTR Lighting interior and exterior bulbs, Morimoto mirror puddle lamps, center console wireless charging tray, RAM Mounts Quick Grip wireless charger, Alpine iLX-F509/DVE-5300/KCX-630HD/DVR-C320R, Maestro RR, Garmin Drivesmart 65 & Traffic, Llumar FormulaOne Stratos Nano-Ceramic Window Tint. More to come...
    I installed the Rago Fabrication Dash Plate with the ICS backing plate. Solid and always getting compliments.
    First, I positioned the loosely assembled bracket on the dash, marked the holes with a center punch, and drilled the holes in the dash. Next, I positioned the backing plate under the dash and marked it through the holes that I drilled in the dash. I used my HF drill press to drill the holes in the backing plate. I felt that the provided screws were a bit short, so I replaced them with 1/4"-20x1" button head screws and 1/4" flat black washers from Lowes. One of the two provided 1/4"-20x3/4" flat head countersunk screws to mount the plate to the bracket was dicked-up, so I found an exact replacement at Lowes.
    I added a Ram Mounts X-grip large phone mount with diamond base RAM-B-102-UN10U that I modified with a CHOETECH wireless charger epoxied to it (before they released a wireless charging mount). It wasn't quite where I wanted it so I added a short double socket arm RAM-B-201U-A and a double ball adapter RAM-B-230U. That combo was too long and wobbly (arm, not plate). I swapped the medium arm with another short arm and that did the trick. I used the medium arm with the power plate RAP-300-1U to mount my Uniden. 10-24x3/4 socket head cap screws from Lowes were used to mount the diamond ball bases RAM-B-238U.20200101_181135.jpg 20200101_181347.jpg 20200101_183151.jpg 20200101_183235.jpg 20200101_185253.jpg 20200101_185311.jpg 20201116_155613.jpg 20201116_170149.jpg
  24. Nov 16, 2020 at 4:22 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Looks good! I got mine installed this weekend
    TSands83 likes this.
  25. Nov 21, 2020 at 10:52 PM
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    18 SR5 CM TSS Offroad
    Thanks for the detailed write up. Waiting on my ICS plate to get here to do the same install. Pics are awesome! Great job on the install!
    AggiePhil and TSands83[QUOTED] like this.
  26. Nov 24, 2020 at 11:45 AM
    iamsjn
    iamsjn New Member
    Shawn
    2014 Tundra SR5
    Really LOVE these Rago Fabrication Dash Plates. I just picked up a 2021 Tundra and am wondering if anyone has heard if these plates fit on them. All of these install pics look GREAT! Good job all!
  27. Nov 24, 2020 at 12:04 PM
    TSands83
    OKC, OK
    Congrats on the new rig. I haven't heard if they do or not. Does your dash have the same recess? The major change I heard of is the infotainment center. Installation/removal procedures will be slightly different. As long as you have clearance under the dash, I don't see why it wouldn't work. But definitely look into it first. Rago Fabrication lists it for 2014-2019. ICS Fab lists theirs for 2014-2020. Call them first. Good luck.
  28. Nov 24, 2020 at 1:55 PM
    iamsjn
    iamsjn New Member
    Shawn
    2014 Tundra SR5
    Yep. The recess is the same. My previous truck was a 2014 Tundra and it’s identical. Was just wondering if anything was different under the dash. I think I’m going to bite the bullet and get it. I’ll be able to make it work.
  29. Nov 24, 2020 at 2:10 PM
    TSands83
    OKC, OK
    I checked online parts catalogs. Part number 55301-0C050-C0 is the same dash from 2014 through 2020. I'm sure 2021 is the same. They just haven't updated the catalogs yet. In everything I've seen, Toyota made no changes from 2020 to 2021. The only thing they did was release a "Nightshade" edition, "Trail" edition, "Lunar Rock" TRD Pro color, and TRD Pro in Double Cab. 2022 will be the major change.
    AK49 (post #13) installed a Rago in his 2020. Dragracer_Art (post #19) installed an ICS in his 2020. I'm pretty sure that the Rago and ICS dash plates will still work in the 2021. It's just so new, no one has updated catalogs or verified fitment. Still, I would give them a call to verify before you go drilling holes in your brand new dash.
    Zilla18 and iamsjn[QUOTED] like this.
  30. Nov 24, 2020 at 3:11 PM
    Zilla18
    Zilla18 New Member
    Scott
    Richmond, TX
    Here are a few pics from my install today. I have the Rago base mount supported by the ICS plate. Needed to drill new holes for Rago to pair to ICS, and added a few more for overall stabilization, a total of 6 bolts with fender washers and locking nuts. I used the longer hardware reccomendations from TSands83 (thank you) and the mount is super secure and made the install alot easier! On the Rago top plate I used RAM mounts. Wireless phone charger (b size) and tablet mount (C size). I utlized the Rago supplied mounting hardware for the install, but may change to the black hardware in the future... Truthfully, the most labor intensive task was skillfully running the charging cables behind the dash! This mount is the real deal, very impressed with quality and detail. There is a little vibration on the tablet mount when driving due to the near horizontal position. I will likely move the diamond mount closer to the front of the plate and utilize a short arm to remedy this issue.
    Shadowfax1, bulldog93, Beesta and 9 others like this.
