Radio won’t turn on. 2018
Discussion in 'Audio & Video' started by spankiee, Apr 12, 2018.
  1. Apr 12, 2018 at 3:22 AM
    spankiee
    spankiee [OP] New Member
    Patrick
    2018 Tundra TRD Sport
    Infinity kappa components front and rear.
    made loud screaming noise through speakers then went blank. It sounded like it got killed. Unresponsive two days later.
    This is entune with nav and apps non jbl.
    Door speaker Amp install gone wrong.
    Have power to back of radio (only one wire has power.) Have power to amp (only one wire has power.)
    Factory amp back in place.
    Checked both fuses “radio” and “amp”.
    Using a ********* amp harness I used the yellow wire to power the amp and the blue wire as a remote, speaker wires to and from amp wired as normal and amp grounded to frame.
    The amp was just a tiny bit bigger than the factory amp 30w x4 it lasted about 10 minutes before assumingly blowing my head unit.
    I’ve tried leaving the negative off the battery for over 10 minutes checked the two fuses what else can I try?
  2. Apr 12, 2018 at 4:34 AM
    U stated *********, have u tried asking them for help with your issue?
    darkknight2014 and Black Wolf like this.
  3. Apr 12, 2018 at 4:37 AM
    spankiee
    Patrick
    I bought a 50 dollar harness.. they got bigger clients to deal with. I tried asking them.
  4. Apr 12, 2018 at 4:39 AM
    Hope it gets resolved, sorry
  5. Apr 12, 2018 at 5:50 AM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Yep but they are pretty good with helping $1 -$1000 ur still a customer.
    Black Wolf likes this.
  6. Apr 12, 2018 at 6:11 AM
    Ac91
    Ac91 New Member
    Dallas
    2018 Tundra SR5
    Have you tried taking it to a reputable shop near by that’s not a dealer? I know most places charge a flat rate for diagnostic fees
  7. Apr 12, 2018 at 6:39 AM
    spankiee
    Patrick
    Not yet, if no one has any ideas on what to check ill take it to ********* it’s about a 3 hour trip for me but they know Toyota’s so I’m sure they will be able to figure it out.
  8. Apr 12, 2018 at 7:40 AM
    Mickleford
    Mickleford New Member
    2016 SR5
    Just for poops and smiles I'd try holding in the volume knob for a while. 10 seconds or longer...
  9. Apr 12, 2018 at 8:08 AM
    spankiee
    Patrick
    Nada..
  10. Apr 12, 2018 at 9:28 AM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Sounds like its the hu id call *********.
  11. Apr 12, 2018 at 9:40 AM
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    Put it all back to factory and take it into your dealership with a confused look on your face. If its the head unit thats the only way you will get a new one under warranty.
    Diverguy and 15whtrd like this.
  12. Apr 12, 2018 at 9:45 AM
    spankiee
    Patrick
    Problem is if they dig in it will be obvious I fucked it up.. I guess I’ll try that first?
  13. Apr 12, 2018 at 9:54 AM
    smooosh
    Ongoing project
    If you didn't cut any wires you should be good i would think.
    Its worth a try. If it does not work you get to buy a new head unit. Your system will sound much better with a new head unit anyway. Here is a video that shows the difference https://www.tundras.com/threads/the-long-awaited-jbl-premium-system-sucks-video.20948/
  14. Apr 12, 2018 at 10:08 AM
    spankiee
    Patrick
    It’s a lease.. was going to return to stock before I turned it back in. So now I will have to buy both.
  15. Apr 12, 2018 at 10:10 AM
    smooosh
    Ongoing project
    Oh dang. Ya try and take it in under warranty once you put it back. If you did not cut any wires you should be good
  16. Apr 12, 2018 at 10:10 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, not sure how they would figure out that you caused the problem. You must have crossed a wire on the amp install. There is a thread on here about using resistors between the HU and LOC or amp. I inquired if anyone has actually blown a HU with aftermarket amp and no replies to that ?. Maybe you are a first.
  17. Apr 12, 2018 at 10:21 AM
    spankiee
    Patrick
    I Wouldn’t be surprised if I were the first.. I literally have the worst luck in the world. I was going to just buy the ********* kit, but was 200$ short so thought by just using the amp I had I could still get the sound I was looking for and still be able to send my son money for college. Looks like I’ll just be without a radio for awhile.. oh well.. at my age you would think I’m out of lessons to learn but maybe I just needed a refresher course... thanks for the help guys.
  18. Apr 12, 2018 at 10:37 AM
    spankiee
    Patrick
    Also not sure the unit is blown, it may be a different problem I will find out tonight. I’m going to do a quick check with an aftermarket head unit if it powers up and plays it’s definitely a blown head unit. If that’s the case, then I think they will just replace it and not dig any further. If that’s not the problem then they will dig and find the obvious tampering of amp wiring and Dynamat doors.
  19. Apr 12, 2018 at 11:34 AM
    spankiee
    Patrick
    Also, the plastic in these trucks specifically the plastic clips are a joke.. broke two so far.. guess the Tundra is a delicate flower that needs to be finessed.
  20. Apr 12, 2018 at 2:18 PM
    War Machine
    War Machine SSEM # 5 3MW
    Hey Adam, he’s in Houston. You or anybody you know have their stock unit still sitting around? I already got rid of mine. I told him to check the Houston Tundras Facebook group.
  21. Apr 12, 2018 at 2:21 PM
    I still have mine in
  22. Apr 12, 2018 at 2:28 PM
    spankiee
    Patrick
    Waiting to get accepted into the Houston Tundras group.
  23. Apr 12, 2018 at 2:29 PM
    U seen All Out Tundras as well?
  24. Apr 12, 2018 at 2:29 PM
    spankiee
    Patrick
    I haven’t, will go look now. Thanks
  25. Apr 12, 2018 at 2:30 PM
    What part H-Town u b from?
  26. Apr 12, 2018 at 2:32 PM
    spankiee
    Patrick
    Cypress jersey village willow brook area where I live they all meet. My zip says jersey village
  27. Apr 12, 2018 at 2:33 PM
    Spring Branch area Clay Rd BW8
  28. Apr 12, 2018 at 2:33 PM
    War Machine
    He’s your neighbor Adam!
    TXRailRoadBandit73 likes this.
  29. Apr 12, 2018 at 2:34 PM
    Yup we all need to get together for some brews
  30. Apr 12, 2018 at 2:38 PM
    spankiee
    Patrick
    I’m down, new to Houston. I’m pretty much BW8 and 249
