Radio shutdown when high beam toggled
Discussion in '2nd Gen Tundras (2007-2013)' started by S&JsTundra, May 25, 2022.
  1. May 25, 2022 at 10:01 PM
    S&JsTundra
    S&JsTundra [OP] New Member
    2013 tundra platinum crew
    New today, toggled the high beams and the radio display shut down for a couple seconds and then came back on. Tried it a few more times and noticed the the speedometer lights went off and speedometer dropped to zero then back to speed I was traveling. Also did it when I turned the headlights on and off, but NOT when I toggled the turn signals. I know my clock spring in the steering column is bad( no horn) and was just about to pull that. Now wondering if that has any correlation, or if it's just the arm mechanism for the headlights and turn signal that needs replacing?
  2. May 25, 2022 at 10:32 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Since you’re adding load to the electrical system when the issue happens, first checks for me would be battery connections (tight, and free of any corrosion), load test the battery, and check body ground cables.
  3. May 25, 2022 at 10:33 PM
    S&JsTundra
    Possible, do have a little corrosion around the battery post that need to be cleaned
  4. May 26, 2022 at 12:06 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Tundras act stupid when the systems dont get full voltage. A bad connection or weak battery can cause all sorts of issues or alerts, often quite unrelated to what you would think a bad battery or connection would cause. Advice above is best first step.
