Radio issues
Discussion in 'Audio & Video' started by Tundra-XP, Aug 6, 2019.
  1. Aug 6, 2019 at 7:37 PM
    Tundra-XP
    Tundra-XP [OP] New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    I was wandering if anyone has had any issues with the radios, 14 Tundra. First it use to reboot while driving and now it freezes up. Cant control the volume, power or anything. I have to shut the vehicle off to reboot the radio.
    TokerJoker likes this.
  2. Aug 6, 2019 at 7:42 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    My ‘14 4Runner does the same exact thing. It goes in stretches with some trips happening over and over, and then we’ll go a while where it is fine(right now- knock on wood). Ours doesn’t get to the point of having to restart the truck. We just hold the power button in and the head unit reboots. I was told we would need to bring it in and have it worked on, updated, or reflashed by a dealer. Doesn’t bother us bad enough to pay to have it supposedly fixed.
  3. Aug 6, 2019 at 7:50 PM
    Tundra-XP
    Will
    I'll have to try holding the power button. It's becoming almost daily lately. Maybe its good argument for a new head unit with apple play. LoL
    TokerJoker, Watt maker and Hammy68 like this.
  4. Aug 6, 2019 at 8:29 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I’ve got a solution. Swap that sheet out.
    In all seriousness try deleting the entune app and or turning off Bluetooth.
    T-Rex266 likes this.
  5. Aug 7, 2019 at 4:49 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Mine use to reboot until I updated.
    https://securedp.toyota.com/download-app/getUpdates
    TokerJoker and Sunnier like this.
  6. Aug 7, 2019 at 6:31 AM
    Sunnier
    Sunny
    San Diego, CA
    TokerJoker and jeremyd[QUOTED] like this.
  7. Aug 7, 2019 at 7:41 AM
    chinadog
    chinadog New Member
    Knoxvegas
    2018 Midnight Black Metallic 1794, 2013 Black Platinum
    Which HU did you go with?
  8. Aug 7, 2019 at 9:01 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    KENWOOD dmx906s with maestro RR. With all the adaptors it will reuse all the trucks peripherals except for the mic.
    Watt maker likes this.
  9. Aug 7, 2019 at 10:51 AM
    chinadog
    chinadog New Member
    Knoxvegas
    That's the one I was looking at, although buried in the details was this that made me nervous. Have not reached out to Crutchfield yet though:
    • Wireless Apple CarPlay will not work without a vehicle speed pulse connection. You will need either a radio replacement interface with a vehicle speed pulse connection or Kenwood's OBD-II Spped Pulse Generation (KNA-SPM100) - both sold separately. Alternatively, you can also hardwire the Kenwood receiver's speed pulse wire to your vehicle's speed pulse wire (this method is much more time consuming and requires more installation experience).
    The link mentioned is not compatible, so that leaves the OBDII connection. Any issue with the wireless CarPlay and the speed pulse connection?
    Thanks (sorry for being off topic post originator).
  10. Aug 7, 2019 at 12:22 PM
    Tundra-XP
    Will
    Nope. This is all great information. I just got off the phone with Crutchfield and looking at a few different models. I thinking of staying with either Kenwood or Pioneer. Pioneer has one coming in with no ship date with all I want since I'm able to pick and choose. One feature I'm looking for is mirroring. The deck will be able to play multi media using an HDMI cord. Still filtering...I like the feed back that keeps coming helping me choose. I doubt I would choose a wireless car play. First too expensive and two I don't feel like paying more for extra wiring harnesses....
  11. Aug 7, 2019 at 1:02 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    There is a VSS signal wire behind the radio. It is the same color as the kenwood wire so just splice it together. I also have a maestro that gets the VSS from the obd port so I wouldn't worry about what they said. Just get it!
  12. Aug 7, 2019 at 4:30 PM
    chinadog
    chinadog New Member
    Knoxvegas
    Oh, it's already in the shopping cart. I can't order it cuz I'm leaving on vacation in a day and don't want it sitting on my front porch while I'm gone!
    I just installed another Kenwood in my daughter's 4Runner. Just making sure I've got everything covered, I had to order extra shit because I didn't have everything I needed when I did the install. Had to take the unit out three or four times before it was finally complete. :)
  13. Aug 7, 2019 at 8:16 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    If you want to use the factory gps antenna make sure to get the adaptor. The gps antenna is the black one. The white one is for sat radio. There is also An adaptor to use the factory USB port. I recommend the maestro rr if it’s not in your cart.
  14. Aug 8, 2019 at 4:55 AM
    chinadog
    chinadog New Member
    Knoxvegas
    It is. :)
    BlueBottle[QUOTED] likes this.
  15. Aug 24, 2019 at 9:59 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Got a '14 and radio just froze while driving thanks to this thread was able to reboot with out stopping.
    Edit: Wife driving.
    Watt maker and jeremyd like this.
