Radio installation HELP!!!
Discussion in 'Audio & Video' started by Parlous, May 2, 2021.
  1. May 2, 2021 at 5:59 AM
    Parlous
    Parlous [OP] New Member
    2014 Tundra 5.7L Crew Max
    What's up fellas. I have a 2014 Tundra crew max limited with non jbl system in it. It has been a long time since I have installed a HU or subs. Just need a little reminder of how it is all done. I have purchased a new HU and installing an old amp and sub I have but I am not sure what harnesses I need. I want to bypass the factory amp and just let the door speakers run off the HU. I will list all of the parts I have already. I appreciate any help.
    Atoto (gen 2) s8 premium
    [IAH10D/QLED Display] ATOTO S8 Gen2 Andriod Car in-Dash Navigation,Premium/S8G2114PM,USB Tethering,Dual Bluetooth w/aptX HD,Android Auto & CarPlay,HD VSV Parking with LRV,SCVC and More https://www.amazon.com/dp/B08HQS15VG/ref=cm_sw_r_u_apa_glt_fabc_DTTZCN3EZ0P75ZCS7AW5
    Metra 70-1761
    https://www.amazon.com/dp/B0002BEQJ8/ref=cm_sw_r_cp_apa_glt_fabc_SHYZSVBRWXR4MEK6H3PJ
    Pioneer GM-D8601
    https://www.pioneerelectronics.com/PUSA/Car/Amplifiers/GM+Digital+Series/GM-D8601
    Pioneer ts-swx2502
    https://stereowestautotoys.com/pioneer-ts-swx2502-sealed-enclosure-with-10-ts-sw2502s4-subwoofer/
  2. May 14, 2021 at 12:27 PM
    Redacted
    Redacted New Member
    MA
    2014 SR5 TRD
    3" level kit
    Hey buddy, not sure how it’s going for you so far but I’m currently in a similar boat. Was going to buy an Atoto Linux based F7 HU but the more I read the less I like. Seems the atoto line of units isn’t compatible with canbus controllers so there’s no way to retain steering wheel controls. Not sure about adapting the GPS antenna nor the backup camera. Idatalink has the maestro to adapt the controls but atoto might not recognize the digital input. It also takes the install cost and adds around 30% to try and adapt Toyota components rather than use just the stereo with aftermarket accessories.
    Have you gotten steering wheel controls to work yet? GPS antenna? Backup cam?
  3. May 14, 2021 at 1:51 PM
    The door speakers run off of the factory amp. I would not cut and hack wires to run them straight to the head unit.
    I would install a line out converter and go that route.
