Radiator Replacement for 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by DVYota, May 27, 2017.
  1. May 27, 2017 at 8:41 PM
    DVYota
    DVYota [OP] Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    I searched the World Wide Web and found numerous people quoting a radiator replacement as a 4 hour job requiring removal of the front bumper and oil cooler. Ain't nobody got time for that. Here is the easiest way I could come up with.
    Tools I used
    This part is pretty important
    Stock radiator
  2. May 27, 2017 at 8:41 PM
    DVYota
    South Carolina
    Basically stock
    Ok let's get started. Make sure your truck's coolant has cooled off before you start.
    Remove your radiator cap.
    On the bottom of the radiator is a drain. You're gonna need a funnel to keep from making a mess.
    Remove the hose from the top and bottom after the coolant is drained
    PhotoNerd and BlueFalconActual like this.
  3. May 27, 2017 at 8:41 PM
    DVYota
    South Carolina
    Basically stock
    Next I removed the fan shroud. There are two bolts.
    Yes, remove this
    No need to remove
    Yes, remove
    No need to remove
    Cool, now top is loose. The bottom sits on the bottom of the radiator (I'll take more pics of that tomorrow
  4. May 27, 2017 at 9:04 PM
    DVYota
    South Carolina
    Basically stock
    Remove this
    Gives you room to access bolts
    I lossened this to get a little more room to work
  5. May 27, 2017 at 9:08 PM
    DVYota
    South Carolina
    Basically stock
    Time to remove the 4 bolts that hold the radiator to the truck
    2 at the top, 2 at the bottom
    This is where the extensions are used to access the lower bolts through the opening in the front bumper without removing it.
  6. May 27, 2017 at 9:13 PM
    DVYota
    South Carolina
    Basically stock
    When the 4 bolts are removed the radiator will be free. Push the fan shroud towards the engine and lift the radiator out. Lower new radiator in. The lower bolts are tricky and can get stuck.
    I grabbed the bolt with pliers and held it in place, pushed the socket and extension through the front bumper while holding the bolt in place. Tightened bolt.
  7. May 27, 2017 at 9:17 PM
    DVYota
    South Carolina
    Basically stock
    Repeat steps with passenger side lower bolt.
    Insert top radiator bolts and tighten.
    Replace guard and clips.
    Tighten oil cooler bolt.
    Fill with coolant.
    I started my truck and allowed it to remove any air from the coolant system and topped it off.
    Rinse and spilled coolant on skid plate off with water.
  8. May 27, 2017 at 11:54 PM
    Nice write up Matt. Thanks for taking the time and sharing.
  9. May 28, 2017 at 4:25 AM
    DVYota
    South Carolina
    Basically stock
    No problem. If I skipped something anyone is welcome to chime in. All the directions I read made this seem like a nightmare job, but it wasn't bad. Took right at an hour. hopefully this help out someone.
  10. Aug 31, 2017 at 6:54 PM
    SHIfTHEAD
    SHIfTHEAD New Member
    Nate
    Fort Mill SC
    08 Crewmax Limited 4wd
    Yeah, nice one!
  11. Aug 31, 2017 at 7:01 PM
    Great write up!!! What was size of socket used n that wrench shown in pic of tools shown?
  12. Sep 1, 2017 at 4:17 AM
    DVYota
    South Carolina
    Basically stock
    I believe it was either 10 or 12mm
  13. Sep 1, 2017 at 5:30 AM
    bicklebok
    bicklebok New Member
    Ronnie
    Thank you for the write up! I'm sure my day will come to replace my radiator, and I will use your write up.
  14. Jul 31, 2018 at 10:23 PM
    Raider77
    Raider77 New Member
    Thanks Matt, quick question. Did you squeeze the hoses to burp the air out or did you just start up the truck?
  15. Jan 17, 2019 at 7:59 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Great write up. This is the process I plan to use in about a week when I need to replace mine. Have a hairline crack somewhere that is causing a slow drip. Thankfully Toyota unlike some manufacturers actually made the engine bay have some room to work in it, making this possible. I'm happy it will be simple!
  16. Jan 17, 2019 at 8:03 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Awesome write up!
  17. Jan 18, 2019 at 11:28 AM
    Dr_Al
    Dr_Al New Member
    Al
    Not sure how many miles were on your Tundra but you might of wanted to replace the water pump. With the radiator out of the way I would think the pump would be pretty easy to get at.
  18. Apr 5, 2019 at 12:21 PM
    Chief 01
    Chief 01 New Member
    PA
    2020Tundra Pro Army green
    What about removing the fan, so u can remove the fan shroud ??
  19. Mar 25, 2023 at 3:55 PM
    texmln
    texmln New Member
    I used this DIY about five years ago to replace the radiator in my 2008 Tundra. I just did the same job in my wife's 2013 Sequoia. One thing that worked for me on the lower bolts is to pull them out using a telescoping magnet tool (careful, they only fit out the front as they have a big washer on them that won't come through the top hole) and then use the tool to get them started again. Make sure your radiator mounting hole is linked up right by looking through the front hole. Put the magnet tool on top of the bolt head and insert into hole. Use the top hole to see the target. Reach into the bumper and turn the tool gripping it as close to the bolt as possible - if you try to turn the handle from the back the telescoping sections tend to just turn within each other down the line. I was able to just get the threads started enough to hold the bolt in place and get my socket and extension on it to finish the job. Note, it's also possible to use a shorter extension from just inside the bumper if you need to. I had to do this on the driver side of the Sequoia because the radar box for cruise control is right in the spot on the bumper grille you need to come through for the bolt.
  20. Dec 19, 2024 at 12:51 PM
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    Does anyone have advice for this same job on a 2.5 Gen? All the videos and guides I see are 07-13. I'm sure the process is the same, except the 14 and newer grills don't lift up with the hood. Does the grill come off or do you have to bust out a variety of socket extensions....
