Radiator question
Discussion in '1st Gen Tundras (2000-2006)' started by gizardlizard, Oct 2, 2024.
  1. Oct 2, 2024 at 3:34 AM
    gizardlizard
    gizardlizard [OP] New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Question on radiators with first generation trucks: is the radiator a completely different design between the first generation Tundras and the Sequoias? I ask, because I see people recommending to change out the rad on the early Tundras, because the transmission lines run thru it for cooling and if it fails, you could lose your transmission. On the first generation Sequoias however, they appear to have a factory installed trans cooler that is independent from the rad. Just wondering if this is true.
    G_unit3000 and Weagle like this.
  2. Oct 2, 2024 at 3:38 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Yes early 2000s the lower portion of the radiator had a trans cooler built in. Many makers did this and some still do. There are many examples of the "pink milkshake" (what you get when mixing engine coolant with trans fluid) and it can be catastrophic for the trans.
    Avoid it by changing the radiator out every 10 yrs or when the tank color shifts from gray to brownish. Luck.
  3. Oct 2, 2024 at 3:42 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I am about 99% sure the 1st gen Sequoia transmission cooler lines also run through the radiator. Sequoia and the tundra double cab are the same platform and share many parts and my 06 DC's transmission cooler lines run through the bottom of the radiator
    Tundra2 and G_unit3000 like this.
  4. Oct 2, 2024 at 3:46 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    if thats the case, what’s the little cooler for in front of the condenser on the first generation Sequoias? Maybe it’s a factory oil cooler??
    G_unit3000 and Weagle[QUOTED] like this.
  5. Oct 2, 2024 at 3:50 AM
    Weagle
    Prattville, AL
    It is the transmission cooler. But it also has fluid lines that run through the radiator.
    I believe the oil is cooled by coolant running from the radiator, but doesn't have a separate cooler
    G_unit3000 likes this.
  6. Oct 2, 2024 at 3:55 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Wow. Interesting. Had no idea the trans was getting cooled multiple ways. Thanks for information.
  7. Oct 2, 2024 at 3:56 AM
    Weagle
    Prattville, AL
    I found that out recently because I'd always thought the transmission cooler system was separate from the radiator until I recently replaced my timing belt and radiator
  8. Oct 2, 2024 at 3:59 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Seems like a risky idea of using the rad to aid trans cooling to me. I would much prefer two separate systems. Electrolysis, or even an internal failure of the rad and now you’d more than likely lose your trans too.
    Weagle likes this.
  9. Oct 2, 2024 at 4:01 AM
    Weagle
    Prattville, AL
    I agree. However if you follow the recommendations of this forum and replace the radiator every hundred thousand miles when you do the timing belt, it very much minimizes and almost eliminates that risk
    and use the appropriate coolant and replaced/flush per manufacturers recommendations
  10. Oct 2, 2024 at 4:02 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    You can always keep your radiator and just bypass the trans cooler portion, just plumb in an aux trans cooler.
    gizardlizard[OP] and Weagle like this.
  11. Oct 2, 2024 at 4:05 AM
    Weagle
    Prattville, AL
    Even though I don't care for the design, there is a reason the Toyota engineers routed it through the radiator. So I strongly suspect that if you bypass the radiator then the transmission fluid would be more likely to overheat or not be as cool under heavy loads
  12. Oct 2, 2024 at 4:08 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Probably best to just keep things as is. Embarrassing to say, but I just found out about the preventative maintenance of installing a new rad every 100k yesterday. My 2001 Sequoia has over 300k with the original rad. Time to place an order. Sure do appreciate all the advice.
  13. Oct 2, 2024 at 4:11 AM
    Weagle
    Prattville, AL
    I just joined the forum about 2 years ago and found out about that myself as well as several other great recommendations from this forum that none of my previous mechanics had done.
    Looking back I had a problem with the radiator and it had to be replaced somewhere between 175,000 and 225,000 miles.
    it's like replacing the water pump, pulleys, tensioner pulley's, etc. while doing the timing belt. By replacing the radiator, you're eliminating a point of failure, is easier to do since you have it broken down for the TB change, and is very much worth it for the price. I believe I got my Denso radiator for about 175. Worth that piece of mind especially given the transmission fluid runs through it
    shifty` and G_unit3000 like this.
  14. Oct 2, 2024 at 4:17 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Get the Denso from Rockauto or other trustworthy place. Do not order it from Amazon
  15. Oct 2, 2024 at 4:21 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    I just did my TB 4 months ago when the truck hit 300k. Bummer I didn’t know about this sooner, but swapping the rad out is a breeze. I already ordered a Denso unit for it. To be honest though, I think I’m going to stick with Toyota Super red coolant in the Sequoia and change it every 30-50k. My 2017 Tundra uses the extra long life pink along with my wife’s Lexus RX 350. I had to change the water pumps on both before 50k because of leaks. Could be a crappy pump design but I’m guessing it’s more fluid related. Seems to be far more issues with the pink causing leaks than the red. The Sequoia manual calls for red anyway and not pink.
  16. Oct 2, 2024 at 4:23 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Way ahead of you lol. I NEVER order Toyota parts from anywhere but a trusted source.
  17. Oct 2, 2024 at 4:27 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I replaced the radiator in my daughter's 02 tree earlier this year. It's pretty straightforward, and yes, the radiator juice goes through it on the bottom. I just pulled the line and quickly turned it up and wedged it to stay back. Only lost maybe a tablespoon of juice. Just remember you'll need a touch over 2 gallons of Aisin pink/red coolant.
  18. Oct 2, 2024 at 4:29 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Also, get you a pool noodle or similar to cut up and stick between the top of the radiator and core support. The old one will be stuck to the old radiator.
  19. Oct 2, 2024 at 4:35 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    Thanks for the tip.
  20. Oct 2, 2024 at 5:28 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It was actually to get the transmission to warm up quicker on a cold start in colder temps/climates.
    G_unit3000 and gizardlizard[OP] like this.
  21. Oct 2, 2024 at 5:31 AM
    Jack McCarthy
    Bill
    North of Boston
    Mine bought from Amazonia was authentic but in the first shipment it came broken. Poor packaging and rough handling that caused the damage. :frusty:
  22. Oct 2, 2024 at 5:37 AM
    Johnsonman
    Austin
    Sequoia
    Power steering cooler - 2nd gen Sequandras have one too.
    Do Tundras have a steering cooler also?
  23. Oct 2, 2024 at 6:02 AM
    NickB_01TRD
    Nick
    KY
    Yeah that's honestly why I don't recommend Amazon for this part. It seems to be authentic but it's always damaged from shipping. I had two of them damaged that way myself.
  24. Oct 2, 2024 at 8:38 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    I believe the trucks with the factory towing package got the extra trans cooler out front but all of them run thru the radiator.
  25. Oct 2, 2024 at 8:55 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    My 2006 Double Cab has the steering cooler. I replaced all my power steering lines earlier this year, and definitely had to deal with that cooler.
  26. Oct 2, 2024 at 9:48 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    A golf tee works to plug the hoses while swapping out radiators.
    G_unit3000 and bmf4069 like this.
  27. Oct 2, 2024 at 10:05 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
    I haven’t looked but surprised they are that small.
  28. Oct 2, 2024 at 10:10 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    My OEM rad lasted 240k lol
    pipe insulator works also. That's what I'm currently using
  29. Oct 2, 2024 at 10:11 AM
    gizardlizard
    Madison,WI
    2017 TRD pro Tundra
  30. Oct 2, 2024 at 10:27 AM
    Jack McCarthy
    Bill
    North of Boston
    Not true. No towing on mine but the tranny cooler exists.
