Radiant red match?
Discussion in 'General Tundra Discussion' started by IndyTundra, Mar 30, 2018.
  1. Mar 30, 2018 at 3:46 PM
    IndyTundra
    IndyTundra [OP] Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    Has anyone found a powdercoat or non-toyota pant that matches radiant red? I have been thinking about powdercoating my Nfab skid plate red to match my truck. It's currently plasti-dipped black but I keep thinking about changing it up. Would really like to try a spray paint first to see if I like it before dropping the money on powdercoat. I just haven't found a color that's at least close.
  2. Mar 30, 2018 at 4:07 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    If you have an auto body supply store near you take your truck there give them the paint code and they should be able to mix you up a few oz’s and put it in a spray can and you can try it out that way and you will be pretty close to the same color. Should cost around $22 buck for a can of it
    IndyTundra[OP] likes this.
  3. Mar 30, 2018 at 4:09 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Not sure about powdercoat, but I would think a good shop could do a colored powdercoat based off the radiant red paint code of 3L5. I think a paint store could mix up some 3L5 and put in a spray can for you. There's also this: https://repaintsupply.com/3l5-radiant-red-p4698.html
  4. Mar 30, 2018 at 6:20 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I never get tired of checking out the that red ride!!
    NewImprovedRon likes this.
  5. Mar 30, 2018 at 6:41 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Me too
    I just don’t have the balls to go red :(
  6. Mar 30, 2018 at 7:18 PM
    IndyTundra
    Ronnie
    Indianapolis, IN
    Thanks! This is very helpful. Looks like that color matches pretty good. I'll be picking up a can or 2 to try it out on my skid plate. Cheap enough that I can always remove it if I don't like it.
  7. Mar 30, 2018 at 7:19 PM
    War Machine
    War Machine SSEM # 5 3MW
    I can confirm. It’s dead on. Ron told me about it for an emblem. And thanks for giving him reasons to post pictures of that truck again.
