Radar Sensor behind Toyota Emblem
Discussion in 'General Tundra Discussion' started by smokey24_24, Jan 19, 2019.
  1. Jan 19, 2019 at 8:39 AM
    smokey24_24
    smokey24_24 [OP] New Member
    I just traded in my 2007 Tundra for the 2019 Tundra. I want to get rid of the chrome on the grill and toyota emblem. I am going to line x the bumpers and grill, but my question is if I Line X the emblem as well, will it interfere with the Sensor behind the emblem?
    Disfigurative likes this.
  2. Jan 19, 2019 at 8:44 AM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    Yes it will interfere. System will not work. The radar sensor is very sensitive to obstructions.
  3. Jan 19, 2019 at 8:49 AM
    smokey24_24
    Is there another solution to changing out the chrome emblem and the sensor still working?
  4. Jan 19, 2019 at 8:53 AM
    Blueknights75
    Ron
    Clayton, NC
    TRD Pro Grill is about the only option that I have seen regarding changing the look.
    Tundras likes this.
  5. Jan 19, 2019 at 8:54 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    Someone on here placed a sticker or decal over their emblem and stated that it did not create a problem with the system. I going to try the same once I find something I like to cover the emblem.
  6. Jan 19, 2019 at 9:07 AM
    smokey24_24
    I'll search for that as well. Would you post a link to it if you find it?
  7. Jan 19, 2019 at 9:10 AM
    Campesino
    Campesino New Member
    2014 Tundra CM Off Road
    Do you have the option of spraying some line-x onto something that won't adhere well (possibly wax paper or cling wrap), and then peeling it off and taping the test patch over the sensor to test it? It would probably be a pain to have to clean equipment and what not for such a small patch but could be worth it. My guess is the line-x is radar agnostic but I wouldn't place much on that hunch.
    Kerch71 and speckmon like this.
  8. Jan 19, 2019 at 9:32 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Are you guys guessing that it wont work, or you know?
    It's a simple radar antenna so this would depend on if the LineX, or paint, has any metals in it. Metallic paint would for sure obstruct the signals it needs to talk between it and the black box its connected to, but if not you could get away with this.
    I'd test it out with a few different materials bonded to some card stock or something you could affix in front of it for a day or so under normal driving. Then you could find out what doesn't interfere with it trying to talk with whatever is in front of it.
  9. Jan 19, 2019 at 9:37 AM
    MaxYota
    Murf
    MS Gulfcoast
    Not sure how the link thing works but it was a thread I started awhile back and this is one of the responses with pics. Not sure if this person is still around the forum or not but if they are hopefully that will pop in and tell if it’s still good to go.
    smokey24_24[OP] likes this.
  10. Jan 19, 2019 at 9:44 AM
    Steve6
    Steve6 New Member
    Tucson
    I know that frost will cause the sensor to malfunction. Don't know about paint tho. In for answers.
  11. Jan 21, 2019 at 6:13 PM
    heywaitfourme
    heywaitfourme New Member
    Chesapeake, VA
    F7C0BE48-0326-43E0-B574-418645B11BCB.jpgI have an 18 and my sensor is mounted in the lower portion of the surround just off center (drivers side). Over 12k miles, no issues, or problems and every system works as it should.
    Akaklutz likes this.
  12. Jan 22, 2019 at 2:38 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    I'm still here and it still works fine.
    I did go out wheeling with a friend over the weekend and after going through a huge mud puddle, I did start getting error notices saying the pre-collision radar was malfunctioning. It was just gloppy mud messing it up though. After I cleaned it off it worked fine again.
  13. Feb 1, 2019 at 6:19 PM
    Welcome from NY.
  14. Feb 2, 2019 at 7:51 AM
    AZPT
    AZPT New Member
    Preston
    Oh my god. I thought it was only right to let you know I just signed up for an account here, instead of continued lurking, basically to tell you how bad a$$ your truck is. Wow. If only I had $60k! ;)
    Kerch71 likes this.
  15. Feb 2, 2019 at 7:53 AM
    Welcome from NY.
  16. Feb 2, 2019 at 9:54 AM
    MaxYota
    Murf
    MS Gulfcoast
    Awesome.
    Thanks for responding cause I was wondering myself if it was still good to go.
    I’m still looking for that “THAT’S IT!!” Sticker. Once I find it, it’s on there.
  17. Feb 3, 2019 at 4:50 PM
    heywaitfourme
    Chesapeake, VA
    @AZPT - Thank you. Wife also said if it were only $60k......
    It’s a slow build and there’s plenty more planned.
  18. Feb 3, 2019 at 5:32 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  19. Feb 4, 2019 at 12:55 PM
    DividedSky
    Jeff
    Yeah... I thought and thought on what to add. Did't want something that was too much of a fad/short term interest, plus I wanted something that had an awesome design.
    Well, I've been drinking Stone Beer as my #1 go-to (costco) for at least 12 years, and I don't plan on stopping any time soon. BOOM!!! Stone Gargoyle!!!
    That's my jam
    MaxYota[QUOTED] likes this.
  20. Feb 15, 2019 at 8:12 PM
    MaxYota
    Murf
    MS Gulfcoast
    Finally found something I like. The Harley Davidson Skull. It was the right height and filled in the emblem rather nice. Been running it for over a week now with no problem. C62C42E8-F7F3-4E6E-A50E-C72A317966F2.jpg EC57F20D-7616-413C-B598-B8272AEEA72E.jpg
    Glockmeister, Kerch71 and DreTRD like this.
  21. Oct 16, 2019 at 4:49 PM
    Jetbeech
    Jetbeech New Member
    Alex
    2019 Blacked Tundra
    I purchased a 2019 Tundra SR5 with the SX package(no badges or chrome). The shiny Toyota grill emblem was out of place. I could not find a blacked out replacement emblem that worked with the sensor system. I was nervous to paint the $300 emblem and lose my sensor(safety) and cruise functions. I followed this thread and some others from other manufacturers with similar systems and finally gambled and painted it. I masked off the emblem while it was still in the grill(I found some videos where they broke the emblem trying to remove it). I used a 3M scuff pad to prep the emblem. Tundra Frt.jpg Emblem1.jpg EmblemPaint.jpg
    The final result was 3 coats of semi-gloss paint. My sensor still works! I have attached pictures. In my research I decided to avoid metallic paint. IMHO it looks much better, your mileage may vary.
  22. Oct 16, 2019 at 6:16 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    That looks sweeeeet!
