Rack and pinion write up
Discussion in '1st Gen Tundras (2000-2006)' started by Hi06silver, Sep 27, 2022.
  1. Sep 27, 2022 at 1:45 PM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Looking for a rack and pinion write up...searched.
    Having some clicking noises when I back outta drive slow then stop also Forward or shake wheel back and forth. Does anyone know what year taco or 4 runner years would be similar for videos off top of their head?
    Gonna try At-205 but I'm guessing I'll have to get a new reman Toyota rack and outer tie rods eventually as the new ones are on back order with no lead time according to Mc George Toyota.
  2. Sep 27, 2022 at 3:23 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
  3. Sep 27, 2022 at 8:42 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I think @bmf4069 might disagree with that.
    bmf4069 likes this.
  4. Sep 28, 2022 at 4:10 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Me and @MrDirtjumper would disagree with that.
    I used the Detroit axle rack. No problems so far. I'd consider replacing your lines too. As soon as I put the new rack on it busted my return line. The job itself is straightforward enough, it's just a pain.
    Sunnier likes this.
  5. Sep 29, 2022 at 8:31 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I recently went with a oem reman and so far so good. Steering is tight and so far no issues. I got thrown a little by the steering wheel and trying to get the number of turns perfect, but it's too bad of a job. Just take your time.
    I used this link for a little tutorial. It's not the exact same, but pretty similar and helps with getting the rack centered. Read it once or twice before diving in and you should be good. And we're here to help.
    https://adventuretaco.com/guide/replacing-the-steering-rack-on-a-1st-gen-tacoma-or-3rd-gen-4runner/
    FrenchToasty and Hi06silver[OP] like this.
  6. Sep 30, 2022 at 4:00 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    Here's a few things I learned from doing my rack.
    1. You can access the upper steering coupler nut from the wheel well if you remove the left side rubber splash shield. You will probably break a few plastic clips, so buy some extra.
    2. Grease the rack body where it contacts the big rubber bushing to prevent rust. Also the A/C drain drips water onto this bushing promoting rust. Extend the A/C drain to redirect that water away from the rack.
    Weagle, Sunnier, w666 and 1 other person like this.
  7. Sep 30, 2022 at 6:03 AM
    Part number and quantities, since I have them handy:
    Splash guard "Apron" fasteners: 9046710186
    Fasteners required: R=5, RR=4, L=8, LL=4 (total 21)
    R is right, forward the strut
    RR is right, behind the strut
    Rinse/repeat for the left L/LL.
    richsadams, Sunnier, w666 and 2 others like this.
  8. Oct 1, 2022 at 9:36 AM
    NetGnome
    NetGnome New Member
    NJ
    My Rack did not come with a dust cap 452220C010.
    I noticed most do not.
    Do most people just buy this dust cap separately or install without it?
  9. Oct 18, 2022 at 10:13 AM
    richsadams
    richsadams New Member
    Northwest
    2000 SR5 AC 4x4 4.7L
    Thanks so much for posting this! I recently bought and installed the Yota splash guards for our 2000 SR5 AC 4x4 and the clips that came with them are a little undersized. Seems to be a common complaint in the reviews. Most are holding but I'd expect they'll all pop out sooner or later. The rubber splash guards themselves are just okay. Some of the holes don't line up well so the rubber gets stretched in some areas and buckles in others. The clip on the driver's side that attaches to the shock tower doesn't hold at all. I tried punching a new hole closer to where one of the holes should be in another one and it immediately ripped into the original hole. :( Still works, but... Better than what was left of the old stuff. Certainly cheaper than the $25 or so Toyota wants for individual OEM replacements I guess.
    I made templates of all of them so if they fail in the future I'll just cut my own out of some tougher material.
    Here are some photos for anyone that follows. I only installed three as one of the originals was still in place and after almost a quarter-million miles, in pretty good shape! :D
    In any case, looked and looked for the PN for the OEM clips and couldn't find it, until now! Thanks! :thumbsup:
    [​IMG] [​IMG] [​IMG][​IMG]
  10. Oct 18, 2022 at 10:35 AM
    Yeah, about that.
    The shock towers just don't hold worth a shit, even with the OEM clips. It's almost like the metal of the tower is thicker and you really hafta mash them in firmly.
    OEM splash guards are similar to what you describe: The holes don't line up well, so the rubber buckles in some areas (no stretching, though). I could tell my old ones were the same way, but with time they'd both shrunk a bit and hardened so it wasn't as obvious.
    So ... just know, it may not just be the product you installed. And for the record, the Yoda set looks identical to OEM, just 10-20% cheaper. The clips they're selling look near identical to OEM also, so you may want to grab one or two of the OEM to compare before going whole-hog.
    richsadams[QUOTED] likes this.
  11. Oct 18, 2022 at 10:40 AM
    richsadams
    Northwest
    Good advice and will do! :thumbsup:
  12. Oct 18, 2022 at 4:38 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I used zip ties for a couple of the holes after breaking some of the fasteners. Seem to be holding without issue. Just a thought. Can’t tell unless you’re looking for them.
    richsadams likes this.
  13. Oct 18, 2022 at 8:28 PM
    richsadams
    Northwest
    Great little hack! :thumbsup:
