Quick question
Discussion in 'Detailing' started by T-Rex266, Jun 13, 2017.
  1. Jun 13, 2017 at 1:40 PM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Grabbed a combo box of Meguairs Quick Detail spray and clay bar. If I understand correctly- spray the detail spray on an area, then kneed the clay into a disc shape in your palms and wax. (Any certain direction this needs to be done? Clockwise?)
    After, wax (scrub) off with a microfiber towel (all I use for drying and such on my truck)
    Was going to try this on my tail gate first and move from there.
    ColoradoTJ likes this.
  2. Jun 13, 2017 at 1:49 PM
    Had to crack one on you...but..what do the directions say on the box or container? :eek:
  3. Jun 13, 2017 at 1:50 PM
    Similar, but there are experts on here who have been through this and probably found a different, more effective way. ;)
  4. Jun 13, 2017 at 1:51 PM
    Booyah!
  5. Jun 13, 2017 at 1:55 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  6. Jun 13, 2017 at 2:00 PM
    I think it is counter clockwise. Wax on, wax off Danielson.
  7. Jun 13, 2017 at 2:04 PM
    Like my bald head?
  8. Jun 13, 2017 at 2:05 PM
    That is clockwise.
  9. Jun 13, 2017 at 2:08 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  10. Jun 13, 2017 at 2:10 PM
    Hope that helps a little Sean.
    driverdog and SouthBoundSteve like this.
  11. Jun 13, 2017 at 2:11 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Jberry is Batman...
    Law323 and T-Rex266[OP] like this.
  12. Jun 13, 2017 at 2:12 PM
    TXMiamiFan
    Jose
    Just giving you $hit
    joonbug[QUOTED] likes this.
  13. Jun 13, 2017 at 2:27 PM
  14. Jun 13, 2017 at 2:29 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I am Batman
  15. Jun 13, 2017 at 2:31 PM
    Law323 likes this.
  16. Jun 13, 2017 at 2:33 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  17. Jun 13, 2017 at 2:34 PM
    T-Rex266[QUOTED][OP] likes this.
  18. Jun 13, 2017 at 2:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    boardude[QUOTED] likes this.
  19. Jun 13, 2017 at 6:05 PM
    Was going to use a compound after. Thoughts?
  20. Jun 13, 2017 at 6:42 PM
    So-
    polisher
    Detail spray
    Claybar
  21. Jun 13, 2017 at 6:45 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    The clay bar will remove impurities. Some like to wax afterwords. It removes deep down grime and things that get into the paint that you can't see with the naked eye. I would do a normal wax when you are finished. Whatever you do though do not drop that clay bar on the ground or it is toast. It will pick up dirt and scratch your ride.
    driverdog and T-Rex266[OP] like this.
  22. Jun 14, 2017 at 4:27 AM
    Fishin1981
    Fishin1981 New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    Using the clay bar it time consuming if you do it properly. If followed by waxing (which I do) you will be very pleased with the end result. I do it once a year.
  23. Jun 14, 2017 at 7:15 AM
    :thumbsup: Thanks for the detailed write up!
    driverdog likes this.
  24. Jun 18, 2017 at 9:19 AM
    Holy hell this is a lot of truck to wax. Almost done with the claybar process.
    I'm thinking the polishing compound is to be done next?
  25. Jun 18, 2017 at 10:07 AM
    Which ever one you suggest.
  26. Jun 18, 2017 at 10:16 AM
    Polishing removes light swirl and hazing
  27. Jun 18, 2017 at 10:17 AM
    Let me check
  28. Jun 18, 2017 at 10:19 AM
    Not really. Most just say it removes the swirls
  29. Jun 18, 2017 at 10:24 AM
    So much time to wax :annoyed:
    SouthBoundSteve likes this.
  30. Jun 18, 2017 at 11:18 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If you like to detail your truck I would suggest a good quality Dual Orbital buffer. I recently bought a Flex 3401 Dual Orbital polisher and it has made a significant difference on my truck detailing. It cost a good chunk up front but I was able to remove almost all the imperfections. It makes my paint look better than when it was brand new. Saves me a ton of time and arm fatigue.
