Quick question about 35" wheels
Discussion in 'Wheels & Tires' started by Fireace, Sep 30, 2016.
  1. Sep 30, 2016 at 2:22 PM
    Fireace
    Fireace [OP] New Member
    Oregon
    2018 Crewmax SR5 CM
    BAmuffler Pro Comp 6” lift ADD bumper Smittybilt 10k winch
    I meant tires :rolleyes:does it mess with your gear ratio? Someone told me it could. Like it would not shift when it was supposed to
  2. Sep 30, 2016 at 2:33 PM
    It'll adjust to it.
    bandit likes this.
  3. Sep 30, 2016 at 4:07 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    I've read this in a lot of places and from my experience even going to 37's I've had zero shifting issues. Caveat is the truck is supercharged so I'm sure that helps quite a bit. I doubt 35's would do any harm.
    T-Rex266 likes this.
  4. Sep 30, 2016 at 4:15 PM
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Had my 35"s for a few months now and truck feels completely normal. Shifts up and down just fine. Only thing I noticed was slight loss in acceleration power since the weight of the tire being much more than the stock tire.
  5. Sep 30, 2016 at 4:49 PM
    Fireace
    Oregon
    2018 Crewmax SR5 CM
    Thanks guys
    bandit likes this.
  6. Sep 30, 2016 at 6:17 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    It does change your effective gear ratio, but not so much as most people would notice. The biggest issue is that it throws off your speedometer calibration. Hypertech makes a calibration module to compensate for tire size changes.
    You should also expect to take a hit on your MPG. The tires are heavier, and usually more grippy. The lift itself, raises the profile of the truck, so that has an impact on its aerodynamics.
    Fireace[OP] likes this.
