Quick oil change queStion
Discussion in 'General Tundra Discussion' started by Robster80, Oct 7, 2022.
  1. Oct 7, 2022 at 12:13 PM
    Robster80
    Robster80 [OP] New Member
    Anyone jack the side of the truck up a bit to drain any extra oil? Id read somewhere some do that but was curious if that was good to do or necessary?
  2. Oct 7, 2022 at 12:29 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The whole point of owning a truck is, no jack needed for oil change
  3. Oct 7, 2022 at 12:40 PM
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    I don’t but I get the logic.
    I do measure how much oil is drained each time It has consistently been 8 qts from the reservoir and probably 1/2 qt or less from the filter housing. This is with no jacks and on a somewhat level surface.
    Robster80[OP] likes this.
  4. Oct 7, 2022 at 12:48 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Never Ever..I can do barrel rolls under my truck :rofl:
    RaginTxn likes this.
  5. Oct 7, 2022 at 2:24 PM
    Robster80
    I meant jack one side up. So the truck is tilting a bit
  6. Oct 7, 2022 at 2:25 PM
    Robster80
    I meant jack one side up so the truck is tilting some.
  7. Oct 7, 2022 at 6:50 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Since the drain plug is on the right side of the pan, lifting the left side of the truck some after the pan is done draining does result in some more oil to drain out. I have done this, although not sure if it makes much differance overall.
    BravoDeltaRomeo likes this.
  8. Oct 7, 2022 at 7:14 PM
    Retired...finally
    Save yourself the trouble and drive the side opposite the drain plug up on a piece of 5/4 decking boards. It doesn't matter if it's 1 degree difference or 10. Except the time to fully drain.
    My Element required driving the front wheels up on ramps for a full drain which was .3 qts more than the standard 5 qt Castol jug. Did all that effort really make a difference especially when every 30K I did a trans fill and drain and only replaced 30% of the fluid?
  9. Oct 7, 2022 at 7:20 PM
    Funnyguy713
    Houston TX
    Just drain the oil while the truck is still warm for better oil flow. That's what I do :crapstorm:and lay down alot of newspaper.
    Mike59 and Retired...finally like this.
  10. Oct 7, 2022 at 7:22 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I use the truck's frame rail for my bench press to drain the extra oil.
    Bammer, TheBeast, C.I. and 4 others like this.
  11. Oct 8, 2022 at 1:13 PM
    Robster80
    I may try it my next oil change. Went on and changed it this morn just parked level.
  12. Oct 8, 2022 at 1:33 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    what's that extra oz of oil going to do, when you are pouring 8 qts of oil back to diluted...
    TheBeast likes this.
  13. Oct 8, 2022 at 2:25 PM
    Mike59
    Mike59 Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    Sometimes I pour a half quart of new oil in while the draining is in progress. Sorta chasing out the old with the new lol.
  14. Oct 8, 2022 at 2:34 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    You win the oil change thread today
    First I ever heard of this
  15. Oct 8, 2022 at 2:54 PM
    Robster80
    That is brilliant
    Mike59[QUOTED] likes this.
  16. Oct 8, 2022 at 3:26 PM
    A little rinse for the drivers side head and the pan anyway.
  17. Oct 8, 2022 at 7:09 PM
    Retired...finally
    Great idea!
  18. Oct 8, 2022 at 10:51 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I do this with my trans too, if I know I'm going to have the extra fluid/oil to use.
  19. Oct 8, 2022 at 10:53 PM
    Retroboy1989
    Northern Utah
    Only when I cannot get to the train yard.
    GODZILLA, TheBeast, Spyker and 4 others like this.
  20. Oct 9, 2022 at 8:37 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Oil will be trapped all over the engine, washing it down or waiting 5 hrs for the last drop does nothing and the old stuff harms nothing. You're better off dropping the pan and giving it a good cleaning, might even reveal the overall engine health... but then thats a lot of messy work and might even require a new gasket...
