quetions about parking sensors
Discussion in '2.5 Gen Tundras (2014-2021)' started by Madball, Aug 4, 2022.
  1. Aug 4, 2022 at 11:08 AM
    Madball
    Madball [OP] New Member
    I just bought a 2020 Tundra limited and when I turn on the park sensor button I dont see anything showing up in either reverse or head on at 12 and 6 o clock positios is this normal? It's my first Tundra, thanks!
  2. Aug 4, 2022 at 11:11 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    First, Welcome from LA (Lower Alabama)!
    The sensors should beep when you get fairly close to an object behind you, or off the corners of the front of the truck. The indicator behind the steering wheel should indicate where an object is being detected.
    Saltyhero13 and Jaypown like this.
  3. Aug 4, 2022 at 11:14 AM
    Madball
    I used to live in Dothan, AL! thanks for the reply I guess they arent working nothing happens when I back up or go forward close to a car or anything I just got this yesterday thats so frusterating!
  4. Aug 4, 2022 at 11:17 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Is the little light on the switch on? Easiest way to check is to back up towards a garage door. It should start beeping the closer you get to it. With an eventual solid tone. If not, get a hold of Toyota to have fixed under warranty.
  5. Aug 4, 2022 at 11:52 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    mines never worked properly on my 2016, even the dealership couldn't re-produce the problem.
    "going off when its not supposed to and stopping when i drive off" so i just leave it off.
  6. Aug 4, 2022 at 12:43 PM
    Madball
    Yeah they switch is turned on and everything, is there an indication on the gauges that’s supposed to come on or just the green switch light?
  7. Aug 4, 2022 at 1:04 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Just green light I believe. I'll verify in 10 minutes when I leave work lol
  8. Aug 4, 2022 at 1:21 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Confirmed. Just a little green light on the switch
  9. Aug 4, 2022 at 6:01 PM
    Madball
    Thanks for getting back to me really appreciate that time to take it back over there
    Jaypown[QUOTED] likes this.
  10. Aug 4, 2022 at 7:06 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I would use the warranty.
  11. Aug 4, 2022 at 7:17 PM
    Madball
    Turns out I’m an idiot they work fine new truck don’t know what I’m doing I have been driving an 04 wrangler for the past 15 years I’m not used to this haha
    Jaypown and GODZILLA like this.
  12. Aug 4, 2022 at 10:01 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The rear ones are not much help since there is a camera but I do like having the front ones for pulling up close to things. There is an indicator on the dash that has lines on how close you are and it beeps faster the closer you get. Only issue with them is in the winter when it snows and ice gets stuck to the bump you have to shut them off or they will just beep non stop.
    User170512 and Madball[OP] like this.
