Questions regarding lift on TRD Pro
Discussion in 'Suspension' started by hdfanatic, Jan 16, 2017.
  1. Jan 16, 2017 at 1:00 PM
    hdfanatic
    hdfanatic [OP] New Member
    Kevin
    Pearland, TX
    2017 Barcelona Red Platinum Crewmax 4x4
    TRD Pro wheels, Nfab
    Just bought a Platinum and looking to get the TRD Pro suspension installed. My question is does the suspension itself provide the lift/level or is there another component installed that is assisting?
  2. Jan 16, 2017 at 1:06 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    The PRO suspension provides 2" of lift over the regular Tundra suspension, its just the suspension itself. Why are you wanting to pay big money for suspension that's not adjustable, rather than getting ones that are?
  3. Jan 16, 2017 at 1:10 PM
    hdfanatic
    Kevin
    Pearland, TX
    Primarily to keep all Toyota parts and make sure that I maintain the warranty. I would probably buy used to save some cash. But I'm not against another system that would provide the same ability.
  4. Jan 16, 2017 at 1:12 PM
    You still retain a warranty if it's not the TRDPro (Bilistein) shocks...
    CM-LENNY likes this.
  5. Jan 16, 2017 at 1:13 PM
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    There is no "saving" money buying TRD pro suspension in my opinion. Just putting in a pair of coilovers and adjusted to level the truck out (I'm assuming that is what you want to do), it will not void any warranty.
  6. Jan 16, 2017 at 1:13 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Unless you cut the frame for a drop bracket, the suspension shouldn't void a warranty. The only way to add lift height to the PRO suspension is with shims.
  7. Jan 16, 2017 at 3:18 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Congrats on the new truck, We have allot of Tundra guys add the PRO suspension for similar reasons. Roman at Cool Springs Toyota will be able to help with your PRO items and if you're need extra height along with improved ride quality we build our Coachbuilder system to do just that. 295/70/18 is most common size used but can bump up to a 35" pretty easy too. Let me know if you need any help sizing or anything else.
    CaptTyler likes this.
  8. Jan 16, 2017 at 3:20 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    You may want to look into the Bilstein 6112/5160 combo.
    Morgan51 likes this.
  9. Jan 16, 2017 at 9:37 PM
    Morgan51
    Morgan51 New Member
    2016 Inferno CM Tundra TRD
    This ^^ Probably the route I'm going when I get into the suspension. Seen the two shocks side by side, they look almost identical aside from red coils, and small reservoirs on the TRD pro shocks. Although, there might be internal differences that make a difference, you can get the 6112/5160 setup for half the price virtually.
    Also, @Coachbuilder1, that MGM pro looks sweet!
