Questions about changing to alloy wheels.
Discussion in 'Wheels & Tires' started by Darby, Sep 26, 2015.
  1. Sep 26, 2015 at 11:49 AM
    Darby
    Darby [OP] New Member
    2011 4.6l V8, double cab
    IMG_2514.jpg I have a 2011 Tundra, double cab, 4.6l and am thinking about getting new wheels.
    Tire size is 255 70/18, currently have steel wheels and like the alloy wheel from Toyota, part #426110C170. They are a TRD black machined wheel.
    http://www.hubcaphaven.com/p/15293/...110c170.html?gclid=CPmepNXJ4McCFcNhfgods04J9w
    Questions:
    • Will I notice a difference in the the handling or ride between steel and alloy?
    • Will my current tires fit?
    • Most of my driving is in the mid-atlantic region….snow, ice, road salt…will this mess up the finish of these wheels?
    Thanks for any advice you can provide!
  2. Sep 26, 2015 at 11:54 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    No difference in ride quality.
    Yes current tires will fit.
    No the finish is fine
  3. Sep 26, 2015 at 12:05 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    ^^X2. But I bet you can find those wheels on craigslist for a lot cheaper and they will probably come with tires. Lots of people get rid of their stock wheels and tires.
    2mchfun and MotoTundra like this.
  4. Sep 30, 2015 at 5:44 PM
    H82work
    H82work New Member
    Nick
    2008 Double Cab
    only dents and scratches
    I have a 2008 double cab and it also came with steel wheels. I just bought a new set of alloy 5 spoke Tundra wheels (no tires)on Craigslist (mdavis is right!!!) here is what I learned...
    1. Lug pattern is 5X150 and fit perfectly.
    2. TPMS on steel wheels are a different angle and you CANNOT transfer those
    3. Lugs are DIFFERENT! The steel wheels have thin lugs and lugs for alloy taper out and is wider
    4. I had to go to Toyota and buy 20 lugs
    5. Discount tires had the correct TPMS and did a free balance and mount
    I can get pics tomorrow and post if it helps.
    MotoTundra and mdavis like this.
  5. Sep 30, 2015 at 5:55 PM
    H82work
    H82work New Member
    Nick
    2008 Double Cab
    I hope I did that right. This pic shows the right and wrong lugs. Also shows the right and wrong TPMS.
    Hope this helps! Nick
    Trooper2 likes this.
  6. Sep 30, 2015 at 6:17 PM
    mdavis
    Michael
    Rock Hill, SC
    Yep. I got burned on the TPMs. The day I took the new rims to the shop to do the swap, I found out about the different angles. Paid $350 at the dealership for new ones and then had to take it back up there to have them program them for another $125. I had no idea you could buy them from discount tire and have them program them. Almost $500 expense I wasn't expecting that day. Wish I would have known about buying them from discount, probably would have been a hell of a lot cheaper. :facepalm:
    H82work likes this.
  7. Sep 30, 2015 at 6:20 PM
    H82work
    H82work New Member
    Nick
    2008 Double Cab
    Correct TPMS... 4X$60
    Correct lugs...20X$15
    Lesson learned...Priceless
    SouthBoundSteve and mdavis like this.
  8. Sep 30, 2015 at 6:28 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I agree, as stated above, there are 3 sets of like new 2014+ TRD take offs (same wheel you are looking at) with like new tires and TPMS for around $1200 on Craigslist all within an hour from me.
    I would take your time and find a nice set close by for a good deal, they will pop up!
  9. Sep 30, 2015 at 6:35 PM
    mdavis
    Michael
    Rock Hill, SC
    I found my 20in limited wheels from a Toyota dealer on eBay for $500 + $50 shipping. Must have been wheels off a truck they lifted and put different wheels on because they still had rail dust on them. And they came with lugs.
  10. Dec 10, 2015 at 5:58 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    What does TPMS stand for?
  11. Dec 10, 2015 at 6:04 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    What is a good cleaning/polishing solution for this type of wheel. These are aluminum, correct?
  12. Dec 10, 2015 at 6:49 PM
    Tire Pressure Monitoring System
    MotoTundra likes this.
  13. Dec 10, 2015 at 6:52 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    Thanks. I just did a Google search.
  14. Dec 10, 2015 at 6:54 PM
    Damn, All this time I thought it meant "Transaction Processing Management Systems."
  15. Dec 10, 2015 at 6:56 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    They're tires not a bank!!
  16. Dec 10, 2015 at 7:01 PM
    Ahhh, Tacoma Park Middle School? Sarc^^^^ (0r : Triply-Periodic Minimal Surfaces )
  17. Dec 10, 2015 at 7:04 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I use a pressure washer and Simple Green to clean wheels, if they are bad I use Mothers wheel and tire cleaner (Not on plastidip, but that doesn't apply to you). The key is not to be abrasive with the wheels, don't scratch them while cleaning them.
  18. Dec 10, 2015 at 7:06 PM
    Ditto. Check Craig's list first. Then use your bartering skills.
  19. Dec 10, 2015 at 7:09 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    Thanks. I saw the Mothers cleaner in Oreillys. It was a soft abrassive cleaner. Glad you mentioned it. Sage advise on being gentle with the abrasive. The wheels have some oxydation.
    MotoTundra[QUOTED] likes this.
  20. Dec 10, 2015 at 7:12 PM
    From pretty much everywhere. Marine brat as a kid. NAS Corpus Christi, TX (Where I was born), El Toro, California, Beaufort,S Carolina, Cheerless Pit,N Carolina, Quantico,VA, back to El Toro, all before I was 10. 13 yrs in Oregon. 17 yrs in S Cali. 4 yrs in Japan. 3 yrs in the Phillipines. 11 yrs in CO minus 10months in Anchorage in 2012. Haven't been to Maryland yet but who knows??
  21. Dec 10, 2015 at 7:21 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    LOL. So you are a vet? I lived in Va. so I knew Tacoma Park, MD.
  22. Dec 10, 2015 at 7:28 PM
    Yes, a vet. 1978 to 1984. Sgt. Did you see the USMC symbol ?upload_2015-12-10_20-25-9.jpg I Googled other acronyms for TPMS. Takoma Park was one. I like sarcasm. Definitely check out your local Craig's List. Lots of decent near new pull offs rim/tire deals to be made.
  23. Dec 10, 2015 at 7:36 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    I just noticed it. Thanks for the service. My brother and son share that symbol with you. Proud of them all.
    T-Rex266 and Black Wolf[QUOTED] like this.
  24. Dec 10, 2015 at 7:38 PM
    Semper Fi. (My dad was in from 1945 to 1965, decorated aviator)
  25. Dec 10, 2015 at 7:39 PM
    j2x
    j2x New Member
    Slidell, La
    2012 TSS Tundra
    Stock
    Semper Fi.
  26. Aug 2, 2016 at 1:08 AM
    TundraWes
    TundraWes New Member
    Wes
    Key West, Florida
    2016 Tundra SR
    On the TPMS sensors. It comes up with Part Number 42601C-0C080 as the correct ones for the TRD Rims. Is that correct?
  27. Aug 6, 2016 at 5:58 PM
    TundraWes
    Wes
    Key West, Florida
    2016 Tundra SR
    The TPMS Sensor for the TRD Alloy Wheels is Part Number 42607-0C080. 96.00 Dollars each at the Dealership.
  28. Sep 14, 2017 at 6:42 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I need your help gents, if you were going to use steel wheels for a week or two and don't care about the TPMS light, can you install standard valve stems in the steel wheels or do you need to use the special TPMS valve stems?
    I have never removed a TPMS to see what they look like.
    Borgs likes this.
  29. Sep 14, 2017 at 7:52 PM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Yes
    Borgs and MotoTundra like this.
  30. Sep 14, 2017 at 8:02 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good news, thank you!
    Borgs likes this.
