Question
Discussion in 'Wheels & Tires' started by AZ_BO, Aug 19, 2021.
  1. Aug 19, 2021 at 6:50 AM
    AZ_BO
    AZ_BO [OP] New Member
    Ricardo
    Colorado Springs, CO
    2018 Tundra SR5
    1) Leveling kit 2) Sound system upgrade 3) Color matched grill 4) Leather seat covers
    I’m having a 3/1 leveling kit installed this coming Tuesday, but still haven’t ordered the tires that I want.
    I am currently running a 255/70R18 on 20MM offset Fuel 18x9 Sledge rims.
    Question, when I do the leveling kit and put the wheel/tire combo, does anyone know if I’ll run into any rubbing issues?
  2. Aug 19, 2021 at 6:53 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    This will no doubt depend on what tires and size you go with. Pretty sure you can safely fit 285/70.
  3. Aug 19, 2021 at 6:53 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
  4. Aug 19, 2021 at 7:20 AM
    AZ_BO
    Ricardo
    2018 Tundra SR5
    defintiely will, my problem is that for time being I’ll retain the wheel and stock tire size until my new tires arrive. So my question is with the lift, should I expect problems with that small of a tire?
  5. Aug 19, 2021 at 7:22 AM
    MadMaxCanon
    If you arent having problems before the lift, i cant imagine how you would with the lift adding more clearance and such, unless they mess up your lift install really bad somehow.
