question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Abrown3912, Jul 28, 2021.
  1. Jul 28, 2021 at 9:28 AM
    Abrown3912
    Abrown3912 [OP] New Member
    2021 Crewmax
    I can get a little OCD when it comes to having the tools I need to work on my vehicles. Has anyone ever had a need for a 24mm wrench when working on your 3rd gen Tundra? My current set goes up to 22mm.
  2. Jul 28, 2021 at 9:29 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think u need 24mm on rear diff drain plug, socket will work too
    HulkSmurf14 and Barrett50 like this.
  3. Jul 28, 2021 at 9:47 AM
    RobertD
    Robert
    DFW, Texas
    I bought the metric deep socket set from HarborFreight just so I had extra sockets and more sizes. Yes they are cheap, but it can save you that one time you need the odd ball socket hahaha
  4. Jul 28, 2021 at 9:55 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    all Japanese manufacture use 8mm,10mm,12mm,14mm,17mm,19mm,21mm,24mm,32mm,36mm. so I get set from 8mm to 21mm then just buy the odd size as I go.
  5. Jul 28, 2021 at 10:35 AM
    Abrown3912
    2021 Crewmax
    Thanks. I have a 24mm socket with my set already. I will probably go ahead and get one. Never pass up an excuse to add tools to the collection!
    I've got lots of Pittsburg in the toolbox.
    RobertD[QUOTED] likes this.
  6. Jul 28, 2021 at 12:27 PM
    AZBoatHauler
    So.Arizona
    24mm is also the fill bolt for the transmission. I have a deep 24mm socket I had used on the diff but needed standard depth to squeeze up to the ATF fill bolt.
    Tcase and/or front diff takes a 10mm hex if you’re 4x4.
  7. Jul 28, 2021 at 12:37 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Don’t forget the 39mm 12 point axle nut socket so that you can remove the CV axle nut.
