question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Miki06, Aug 13, 2020.
  1. Aug 13, 2020 at 8:18 PM
    Miki06
    Miki06 [OP] New Member
    I will move to Alaska from Texas I have a 2020 Tundra TSS 4WD.
    I am planning to tow my wife 2012 toyota Highlander (4,300LB). The U-HAUL vehicle transporter I am renting is about 2000LB.
    Do you guys think I will be able to tow it all the way to Alaska?
    Any advice will be appreciated.
    Thanks.
  2. Aug 13, 2020 at 8:24 PM
    Your towing capacity is right around 9,000 to 9200 IIRC.
  3. Aug 13, 2020 at 8:52 PM
  4. Aug 13, 2020 at 9:00 PM
    AZBoatHauler
    So.Arizona
    Which bear is best?
    Billy I, Cpl_Punishment, SOB and 3 others like this.
  5. Aug 13, 2020 at 9:03 PM
    AZBoatHauler
    So.Arizona
    I think you’d be fine other than some chips to the paint of the Highlander. Have you given any thought to driving both vehicles to AK instead of towing? You’re Tundra will get about 9-10 MPG towing instead of 16-17 highway driving...
  6. Aug 13, 2020 at 9:58 PM
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    There are two schools of thought on this
  7. Aug 13, 2020 at 10:03 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I vote the Alaska brown bear.
    T-Rex266 likes this.
  8. Aug 13, 2020 at 10:05 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    The polar bears of Alaska are fantastic!
  9. Aug 13, 2020 at 10:17 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Don't forget King Fu Panda!
  10. Aug 13, 2020 at 10:26 PM
    wiretwister
    NJ
    '22 SR5 CM
    Both of you lose:annoyed:
    Ruggybuggy and hagrid like this.
  11. Aug 13, 2020 at 10:26 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
  12. Aug 14, 2020 at 4:06 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    I trailer-ed my daughters car from Va. Beach to South Dakota. No problems.
  13. Aug 14, 2020 at 5:03 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Bears
    Beets
    Battlestar Galactica
  14. Aug 14, 2020 at 8:13 AM
  15. Aug 14, 2020 at 8:48 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Take the ferry from Haines to Prince Rupert, BC and drive the rest...that's the BEST way you should do this as I have done the same several times (leaving AK and back and leaving again, etc.)
  16. Aug 14, 2020 at 8:54 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Is that the most direct way through BC? The RCMP and CBSA have been monitoring Americains going through and issuing large fines for individuals not taking a direct route.
  17. Aug 14, 2020 at 8:56 AM
    HulkSmurf14
    2014 Tundra Limited
    I'm not sure on this...it's a service that has been or used to be, a good alternative to driving through...though the drive isn't bad, it's worst tho if you're towing with the tundra...I was figuring it would almost be a wash on costs (usually higher on a ferry) since all transportation have been curbed for the most part...I'm not sure though...
  18. Aug 14, 2020 at 8:58 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would definitely be contacting Canada border services to OK the route.
    HulkSmurf14 likes this.
  19. Aug 14, 2020 at 11:21 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    False. Black bears.
  20. Aug 14, 2020 at 5:37 PM
    wiretwister
    NJ
    '22 SR5 CM
    Michael!!!!!!!!!
