Question
Discussion in 'Wheels & Tires' started by Santacruzthor, Aug 13, 2019.
  1. Aug 13, 2019 at 5:08 PM
    Santacruzthor
    Santacruzthor [OP] New Member
    2018 Limited 4x4
    ADS Adjustable Coil Overs, Camburg Upper Control Arms, Differential Drops Kit. Fuel Vector 20x9 Rims w/Nitto Terra Grappler 34’s. 4” Front Lift, 3” in the rear.
    I have a 2018 Tundra 4x4, Limited. I want to change Wheel/tire set up to WITHOUT any Suspension alteration (Level, Lift, ect). I discussed with my local tire store and told the attendant that I wanted a tire/wheel set up that will fill the wheel well area. I’m told the following will give the look/size I’m looking for:
    *WHEEL: Fuel Vector, Matte, 20x9
    * TIRE: Nitto Grappler, G2, XL, 305/55R20
    Question, will this combo fit my current stock set up without any rub or driving hinderance?
  2. Aug 13, 2019 at 5:16 PM
    Welcome from NY.
  3. Aug 13, 2019 at 5:21 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Yes ,he is correct.I have a 13 crewmax with 20x10 bmf wheels and nitto ridge grapplers 305/55/20. I have a 3-1 level kit and not much room at full turn.You will rub with stock suspension.
  4. Aug 13, 2019 at 5:28 PM
    Santacruzthor
    2018 Limited 4x4
    Can you recommend a size with the wheel/tire I mentioned?
  5. Aug 13, 2019 at 5:41 PM
    tenntundra
    Walter
    Tennessee
    You should be able to get some info from some of the other guys on the site.Good luck!
  6. Aug 13, 2019 at 6:32 PM
    MakMurph
    MakMurph I'm here
    Great communist state of New York
    2019 Super White TRD PRO
    Window tint,RB20 running boards,Falken wildpeaks 295/70/18, CB +2 shackles, CB bumper shim kit, TRD rear sway bar, spidertraxx 1.25” wheel spacers,
    Bottom of website homepage, wheel and tire guide.
