QUESTION: What is CORRECT Torque Specs for Shackles??
Discussion in 'Suspension' started by mightyowl, May 8, 2020.
  1. May 8, 2020 at 5:43 PM
    mightyowl
    mightyowl [OP] New Member
    Howdy!
    Shackles Torque Question...
    What is the correct Torque specs for shackles?
    **I am asking because there seems to be many many different answers floating around. Coachbuilder says 90 on his, but also read 85-90 on Toytec. Then again, I also read 77 for factory.
    Love to hear some feedback on what kind of shackles you got and what you torque it to.
  2. May 8, 2020 at 5:45 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I cranked my to 90 and called it a day!
  3. May 8, 2020 at 5:48 PM
    mightyowl
    what kind of shackles?
    My concern is that if this part is over torque it may obstruct the free flow of movement needed by the shackle/leaf spring
  4. May 8, 2020 at 5:49 PM
    anthonygan
    2017 Cement TRD PRO
    I am using the coach builder ones! That’s a very valid point you bring up!
    mightyowl[QUOTED][OP] likes this.
  5. May 8, 2020 at 5:52 PM
    mightyowl
    I decided to run MAXTRAC shackles. They look almost identical to OEM but longer and a bit thicker.
    With that said, I torque mine to 80 ft.lbs thinking they are similar design to OEM which are at 77. I guess this justifies?
    anthonygan[QUOTED] likes this.
  6. May 9, 2020 at 4:12 PM
    mightyowl
    Anyone?
  7. May 9, 2020 at 5:46 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Installed ToyTecs and torqued to 80 ft lbs.
    Tundra234 likes this.
  8. May 24, 2020 at 6:58 PM
    Same here.
  9. May 24, 2020 at 7:03 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    If you're unsure you should base it off of the size and grade of the bolt. Hopefully the manufacturer chose the appropriate bolt for the application.
    theBIGnaud likes this.
  10. May 24, 2020 at 7:19 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Does this even count, My arm was enough to slide my 205lb body and then I called it a day. I don't even own a torque wrench, Lol
