question on TPS when upgrading tires
Discussion in 'Wheels & Tires' started by SiberianTundra, May 18, 2019.
  1. May 18, 2019 at 10:16 AM
    SiberianTundra
    SiberianTundra [OP] I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    I upgraded my wheels in 2018 Toyota Tundra SR5 Crew.
    Kept my original tires and TPS. But what would I need to do if I want to go bigger tires. Will I need different sensors? Can I re-use the current sensors.
  2. May 18, 2019 at 10:26 AM
    Midway
    Midway New Member
    Yes, you can easily swap the sensors. Just had mine swapped three weeks ago.
    I went from stock to running 35s.
    SiberianTundra[OP] likes this.
  3. May 18, 2019 at 10:39 AM
    SiberianTundra
    Greg
    War Machine
    can you shine some light on the brand of the sensors and what was involved in setting them up?
  4. May 18, 2019 at 10:42 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    You don't need to swap sensors to go to larger tires as they only detect pressure.
    SiberianTundra[OP] and Trooper2 like this.
  5. May 18, 2019 at 10:51 AM
    SiberianTundra
    Greg
    War Machine
    Oh interesting! Thank you
  6. May 18, 2019 at 10:52 AM
    Midway
    Midway New Member
    I had a shop swap the OEM sensors to my new wheel/tire setup (ICON Rebounds 17" w/+25 Offset) (35/12.5/17 BFG KO2s).
    Honestly, I have no idea of the sensor brand.
    Everything works perfectly (I spend a lot of time on sand).
