Question on going bigger
Discussion in 'Suspension' started by NjDevilToy, May 29, 2019.
  1. May 29, 2019 at 9:21 PM
    NjDevilToy
    NjDevilToy [OP] New Member
    MGM tundra
    Hi everyone. Have a question I can’t quite find an answer to. I currently have a zone five inch lift on my truck. Was wondering if I could get some bilstein 5100s adjustable and maybe add an inch or two that way. Would that work out or would the angles be too much. Also I should be fine adding two inch shackles in the rear? Any advice in this matter would be appreciated. Thank you in advance.
  2. May 30, 2019 at 8:02 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    1 inch shouldn’t be a problem. A shim or an adjustable shock would work fine. As far as the rear, shackles are fine. You may have to space out the carrier bearing if your getting some shakes..
    NjDevilToy[OP] likes this.
  3. May 30, 2019 at 12:07 PM
    NjDevilToy
    MGM tundra
    Thanks appreciate the input. I’m wondering if I could get away with the 2.1 setting in the front.
    jeremyd[QUOTED] likes this.
  4. May 31, 2019 at 8:09 AM
    NjDevilToy
    MGM tundra
    Anyone out there have a similar set up so I can visually see it. Thanks in advance
