Question on cold weather starting
Discussion in '2nd Gen Tundras (2007-2013)' started by Jon1979, Feb 6, 2022.
  1. Feb 6, 2022 at 5:40 AM
    Jon1979
    Jon1979 [OP] New Member
    Jon
    Upstate NY
    2011 Gray Tundra SR5 4.6L V8
    Hi Everyone
    I have a 2011 Tundra with about 180,000 miles on her and I have an interesting issue when I go to start my truck when it is below 20 degrees outside. When I first turn the key, the truck starts up but will sputter and then stall. I turn the key again right away and she will fire up perfectly.
    The battery is less than a year old and I replaced the plugs last years. Besides the cold starting she runs perfectly and will start just fine in warming weather.
    What I would like to know is if this a common thing or is it the indicator of something that is slowly failing? IE fuel pump
    Thanks.
  2. Feb 6, 2022 at 3:12 PM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Is it Flex fuel? They are known for having a starting problem, especially when there is no E85 in the tank but the truck thinking there is.
    Greg
