Question on after installing SAIS bypass kit
Discussion in '2nd Gen Tundras (2007-2013)' started by Jon1979, Apr 9, 2020.
  1. Apr 9, 2020 at 3:36 AM
    Jon1979
    Jon1979 [OP] New Member
    Jon
    Upstate NY
    2011 Gray Tundra SR5 4.6L V8
    Hey everyone
    Despite reading everything here on the troubles with the SAIS system. I was bull headed and I replaced the bank one valve on my truck which was stuck open. After having two days of trouble free driving the check engine light came back on and now valve 2 was failing like I had been warned. I ordered the bypass kit from Hewitt tech that night. Parts Geek did except my return on the valve, however but I still am waiting to see how much they refund me.
    My question is what can I remove from the truck after installing the bypass module? Obviously the kit comes with the block off plates so I can remove the valves from bank 1 & 2. Can I also remove the pumps and hoses as well?
    Since I am furloughed for a few weeks I though it would be a good time to replace the valve cover gasket and sparkplug tube seals on the right side as well.
    Thanks for the help everyone.
  2. Apr 9, 2020 at 6:17 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    My thoughts when I did my 2010 was leave it all there for emissions testing to not raise attention.
    14burrito likes this.
  3. May 29, 2020 at 5:38 PM
    5ive7even
    5ive7even New Member
    Brett
    Nova Scotia
    silver 2007 regular cab long box sr5
    Leveled w/ Bilstein 5100, 1.5" spacers & rear airbags, factory alloys wrapped w/ 275/70r18 Goodyear Duratracs and a SS Magnaflow 12588
    at what point is It a good idea to do the SAIS bypass?
    do you wait for your truck to throw a particular code or are people doing this as a preventative measure?
    just read about the SAIS issue and not really sure what to think.. do I wait for something to happen or is this something I should be looking at doing right away?
    not familiar with the air injection system at all so if anyone could explain what it actually does that would be appreciated as well
  4. May 29, 2020 at 5:40 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Looks like the air pump system breaks, then its easier to just bypass the computer sensors than fix it
  5. May 29, 2020 at 5:42 PM
    5ive7even
    Brett
    Nova Scotia
    alright so would it be recommended to bypass it before it breaks?
  6. May 29, 2020 at 7:35 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Im not. What if my pump lasts for 4 more years? No reason the spend money that i might not need to spend right now
