Question four-wheel drive
Discussion in 'General Tundra Discussion' started by Mike2020, Aug 24, 2022.
  1. Aug 24, 2022 at 4:50 AM
    Mike2020
    Mike2020 [OP] New Member
    2012 tundra
    3 inch lift
    2012 tundra tried to put in four-wheel drive would not go four high light blinks. Put back in two wheel drive four highlight constantly blinking and anti-skid light came on where do I start disconnected battery light still blinks constantly
  2. Aug 24, 2022 at 8:56 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    So this is the 4x4 actuator very likely getting stuck. Search for this around the forums.. you will get many threads that discuss this issue and also if you are handy, fix it for cheap.
    Suprafantx likes this.
  3. Aug 24, 2022 at 9:05 PM
    baraynavab
    Atlanta
    Ooh and another thing.. Always use your 4x4 system from time to time.. i.e. at least 1/2 times a month. Also make sure you are on mud or loose gravel while engaging 4x4.
    One thing you can try to do is start driving in 2x4 and see of the 4x4 switch can activate the 4x4.. its worth a try.
  4. Aug 24, 2022 at 9:49 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    If you have a straight shot of highway can throw it in 4hi, just make sure to shut off before needing to turn. I'll throw mine in 4lo when Im parking and just go back and forth in a straight line.
    I read this recently. Might help you.
    https://www.tundras.com/threads/3rd-gen-transfer-case-fix-stuck-in-4wd-fix.71027/
    baraynavab[QUOTED] likes this.
  5. Aug 25, 2022 at 5:55 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I usually toss the truck in neutral while still moving a few mph and then turn the knob to activate 4HI. I do the same when shifting back into 2wd.
    I know the system is supposed to be able to shift on the fly (upto 50mph.?), but I'm usually about 5mph and coasting in neutral. I HAVE activated at like 35mph when the highway got shitty enough, but still threw it in neutral.
  6. Aug 25, 2022 at 6:35 AM
    baraynavab
    Atlanta
    It can go into 4wd HI up to 60mph...maybe even 65mph iirc.
  7. Aug 25, 2022 at 7:42 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Have you tried moving the truck (forwards/reverse)? Sometimes it just needs a little movement to align the gears in order for the shift fork to slide over and engage 4Hi.
