Question before ordering lift kit....
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dmull1023, Feb 2, 2022.
  1. Feb 2, 2022 at 5:20 PM
    Dmull1023
    Dmull1023 [OP] New Member
    2020 White Tundra Limited TDR OR
    Looking at a Toytec lift kit (3") for my 2020 Limited. Just installed TRD rear sway bar and started thinking...if I get the kit, is the rear sway bar now obsolete and needs to be removed? Thinking that the extension links on the side of the sway bar will now need to be longer with the addition of a lift.
    Appreciate any knowledge passed my way. TIA.
  2. Feb 2, 2022 at 6:15 PM
    wht100
    wht100 4x4
    Heavy foot
    How high you lifting rear? I’d imagine 1-1.5”? If so, rsb should be fine. My buddy has 1.5” shackles and rsb. Works.
  3. Feb 2, 2022 at 6:20 PM
    Dmull1023
    Thanks, just looked, and lift at rear is 1.5".
  4. Feb 2, 2022 at 6:21 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If needs be, you can always install the sway bar u-bolts on the backside of the axle vs the underside. It'll give you the room you need.
    wht100 likes this.
  5. Feb 2, 2022 at 6:22 PM
    wht100
    wht100 4x4
    Heavy foot
    That works too lol
  6. Feb 2, 2022 at 6:23 PM
    Dmull1023
    Thanks, just found a thread where this exact thing was done to help keep the 90 degree orientation of the RSB.
  7. Feb 2, 2022 at 6:26 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It worked for me until I recently did a block delete. I had to order the longer BDS links
