Question about towing Atv and camper
Discussion in '2nd Gen Tundras (2007-2013)' started by atkinson94, Apr 12, 2023.
  1. Apr 12, 2023 at 7:48 AM
    atkinson94
    atkinson94 [OP] New Member
    kevin
    2008 timberland green tundra sr5 crewmax
    3inx2.5 leveling kit 35x12.5x20 tires
    I hve a 08 tundra 5.7 sr5 4 door 2wd with tow package
    I currently drive around with my 2022 polaris sportsman 450 in bed it Weighs about 750
    We are getting a 2017 crossroads sunset trail superlite 290qb it weights about 6200 lbs with a 824 hitch Weight
    I will have a husky weight distribution hitch with sway control
    My question is can I haul the atv in bed as well as tow the camper. I know that triple pulling in an option but a lot of the roads I go are to tight to make those kind of turns
  2. Apr 12, 2023 at 7:53 AM
    You'll be over you payload and potentially the rear axle weight rating by quite a bit. It won't handle great either. So probably not the best setup. But it probably won't make the truck explode either. Guess it depends on where you're going and how you choose to get there. Not gonna be safe or pleasant going 75mph down the interstate.
    twotrack likes this.
