Question about my battery
Discussion in 'Audio & Video' started by cjscinta, Apr 24, 2019.
  1. Apr 24, 2019 at 4:47 PM
    cjscinta
    cjscinta [OP] New Member
    Nashville TN
    My tundra is less than 2 years old. About 8 months ago I was hit on the side by another driver and my truck was in the shop for a month. When I got it back the battery was dead. I know it’s not good to run a battery down but when I had my car at the dealer afterward they said my battery was fine.
    Today I was in the driveway installing new speakers and had the music on for 30-45 minutes. Went to start it and the battery was dead again.
    Is it normal for a battery to die just for listening to the radio for 45 minutes or do you think I really do have a bad battery? I know if I keep on running it down it WILL eventually go bad. I have a feeling if it is bad Toyota will probably balk at giving me a new one.
    What do you all think?
  2. Apr 24, 2019 at 5:41 PM
    cjscinta
    Nashville TN
    I was kind of thinking that too. I may have to fight them on it but I’m going to try. Thanks for the input.
  3. Apr 24, 2019 at 6:57 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    They may pro rate a battery so might be better off just buying one yourself. If you have an amp it will kill a battery a lot quicker. If no amp a 1/2 hour is no bueno.
  4. Apr 24, 2019 at 7:04 PM
    cjscinta
    Nashville TN
    So are you saying with no amp you can still kill a battery in 30 minutes just listening to the radio?
  5. Apr 24, 2019 at 7:06 PM
    cjscinta
    Nashville TN
    You might be right. If I do buy one, didn’t I see a thread one time about a better battery for the tundra? Seems like it was red but I don’t remember the name of it.
  6. Apr 24, 2019 at 7:39 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    The battery is probably going bad when your truck went to the shop. They probably had doors left open without thinking about turning of the interior lights and cargo lights to save your battery. Chances are it may have died while in shop due to that.
  7. Apr 24, 2019 at 7:54 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    There has been several battery replacements on here in the 2 year range, a few even less time. The factory one isn't always Primo...
  8. Apr 25, 2019 at 6:27 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    OP has two years in, likely battery is 3 years old. I've seen parts of Tennessee hit triple digits in the summer. Buy an AGM and be done worrying about it. Some mechanic or install tech leaves the door open for an hour, no big deal. I have a Northstar 27F arriving Friday and my battery is still miraculously ok after 4 years. 4 years for flooded is pretty good. Might get 5 but it's not worth the risk/savings. You'll have a monster reserve too. Listen to your radio till you get bored.
    NewImprovedRon likes this.
  9. Apr 25, 2019 at 6:29 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Check with you local Advance, O'Reilly, etc to see if they can test it for you. You'll have a quick answer to your question before heading to the dealer and raising hell. :thumbsup:
    Hol Milk likes this.
  10. Apr 25, 2019 at 7:52 AM
    cjscinta
    Nashville TN
    Thanks all. Looks like it’s a Northstar AGM for me.
    Tierhog likes this.
  11. Apr 25, 2019 at 7:58 AM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    My tundra sits in garage all week thx to take home company bucket truck I drive daily:)
    So I keep a battery tender on him in till weekend - have herd on here of a lot of premature “dead” batteries- good luck
  12. Apr 25, 2019 at 8:00 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Is the battery really bad, or was it just hanging out with the wrong crowd?
    Slayer and Midnite72 like this.
  13. Apr 25, 2019 at 10:50 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I am saying if the radio kills the battery in 1/2 with no amp then that is not good. A good battery should easily power an ampless radio for a 1/2 hour. Although because of the lack of an ACC key position in newer vehicles a radio will kill a battery quicker than the old days. Plus the radio itself probably takes more juice with the screens they now have.
    CMB likes this.
  14. Apr 25, 2019 at 8:07 PM
    cjscinta
    Nashville TN
    I have the same problem. My truck sits in a parking lot for 3 or 4 days before I drive it again. I have a battery tender at home but no place to plug in in the parking lot. Probably not helping my battery life.
  15. Apr 25, 2019 at 8:10 PM
    cjscinta
    Nashville TN
    I am assuming the Northstar fits in the standard rack? I don’t really want to do modifications to accommodate it. It looks bigger in the picture.
  16. Apr 25, 2019 at 9:00 PM
    Tierhog
    Tierhog SIG-AHOLIC
    27F Northstar is a perfect fit.
    NewImprovedRon and cjscinta[OP] like this.
  17. Apr 25, 2019 at 10:26 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Thanks for that info.
    Tierhog[QUOTED] likes this.
  18. Apr 26, 2019 at 3:37 AM
    Midnite72
    Bill
    Northern MD
    18 SR 5.7 4x4
    Yea that sucks- just a thought but you could by an inverter that plugs into truck interior to power battery tender then somehow run secondary leads under hood to charge your battery while sitting- kind of funny I guess- inverter would be draining battery at the same time it would be charging
    :annoyed:
    JM2C- good luck bud
  19. Apr 26, 2019 at 6:44 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I've fit a group 31 in, but you'll need longer J-hooks for the hold down, and you'll need to extend the positive cables...and possibly the negative depending on what terminals you use with it. It's a little bigger than a group 27.
  20. Apr 26, 2019 at 8:09 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    Although I've not done it in the Tundra yet, I did have a 2012 Highlander that would go dead listening to the radio for about 15 minutes. At least dead enough not to start. Our Scion is about the same. And they had brand new batteries.
  21. Apr 26, 2019 at 8:13 AM
    Tierhog
    Tierhog SIG-AHOLIC
    I seriously considered it as I pride myself as an "overkill build" guy. The numbers are so high compared to stock I couldn't rationalize it however. Nothing outside a wireless charger and inefficient stock headlights which I aim to fix this summer when an extra 850$ drops in my lap. Lol
    UTTundra[QUOTED] likes this.
  22. Apr 26, 2019 at 8:16 AM
    Tierhog
    Tierhog SIG-AHOLIC
    I worked for Snohomish for a bit, wouldn't want to be in the outskirts with a questionable battery. Your Toyotas deserve an AGM...
    :benchpress:
  23. Apr 26, 2019 at 8:17 AM
    apwisher
    apwisher New Member
    Everett, WA
    I just carry a starter pack anymore. fits in the glove box and have been able to help many folks with it.
  24. Apr 27, 2019 at 7:31 PM
    Tierhog
    Tierhog SIG-AHOLIC
    Room to spare... See
