question about LPG valves
Discussion in 'Off-Topic Discussion' started by gosolo, Jul 28, 2023.
  1. Jul 28, 2023 at 7:26 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    Does anyone here know if there is a difference between the valves used for LPG when it is in a gaseous state and when it is in a liquid state.
  2. Jul 28, 2023 at 8:24 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I'm going to say yes, but, I can't really find anything specific in my vast research in the last 10 minutes :D. Biggest thing I can definitely find is the temperature problem. The Liquid form is a lower temperature than most of the gas hoses are rated for... I have to imagine that this is true for the valves as well.
    I found one site where you can buy valves specifically labeled as Liquid valves :notsure:, https://www.jtcvalvesales.com/valves/lpg-valves.html
    What use case do you have that you need to work with Liquid Propane?
    gosolo[OP] likes this.
  3. Jul 28, 2023 at 8:26 PM
    Dude... you're neighbor has all these answers.
  4. Jul 28, 2023 at 8:28 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    :rofl::rofl::rofl::rofl:
    GODZILLA[QUOTED] likes this.
  5. Jul 28, 2023 at 8:38 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I did do some research before posting.
    I installed a tap on the top of my 500g propane tank today so I can fill my smaller tanks myself. I plan to add a quick disconnect for the feed so I don’t have to leave the fill hose out in the weather. The quick disconnect lpg couplers don’t indicate if they are rated for liquid propane that will be flowing.
    APalmTree[QUOTED] likes this.
  6. Jul 28, 2023 at 8:54 PM
    APalmTree
    Brandon
    SW Washington
    Gotcha. This nash brand one states that it is rated for both http://www.nashfuel.com/partbymfg.a...rass-quick-connect-propane-lpg-hose-line-tank
    The few big tank transfer kits that I have seen have a large "quick disconnect" hand screw fitting just behind the valve that is screwed directly into the tank... not sure if yours has that
    gosolo[QUOTED][OP] likes this.
  7. Jul 28, 2023 at 9:07 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I like it. It is 1/2” npt where I will be installing the q d. Will check and see if they carry it in 1/2”
  8. Jul 29, 2023 at 4:40 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    If there's a chance of flashing propane across the valve, what we do in the refinery is have two valves in series with the first one being quick closing (e.g. quarter-turn) and the second one being used to throttle the flow. (We also make the first valve self-closing, which might be overkill for your use.)
