Question about 2018 Limited ->2019 Pro grill
Discussion in '2.5 Gen Tundras (2014-2021)' started by Lyon, Mar 16, 2021.
  1. Mar 16, 2021 at 10:19 AM
    Lyon
    Lyon [OP] New Member
    2018 Tundra Limited
    I know this has been discussed, but I'm having trouble finding the correct info...I have a 2018 Limited with TSS. I've ordered a 2019 Pro grill to install.
    I don't quite understand if I'll need to buy a new sensor for the TSS or just a cover or nothing at all, or what?
    Thanks in advance for the help
  2. Mar 16, 2021 at 10:54 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    I don't have a 2019 Pro grill, but my 2018 Limited with TSS has a 2017 Pro grill. I mounted the sensor near the bottom 2/3 of the grill behind an AJT bracket. Did not recalibrate or anything like that. I've had no issues. So, if there's a mounting plate on the newer 2019 Pro grill that has the same hole layout as your sensor, you should be OK. I don't know if the bracket holes for 18 and 19 are same, I'm assuming that is what you are asking. Not much help, sorry, but even if you redneck mount it by making your own bracket you should be OK.
  3. Mar 16, 2021 at 11:14 AM
    Lyon
    2018 Tundra Limited
    Thanks for the reply. I think the 19 and 17 pro grills are different enough that what works for one doesn't work for the other.
  4. Mar 16, 2021 at 11:36 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    You’ll need to buy a garnish to cover the sensor.
  5. Mar 16, 2021 at 11:39 AM
    timsp8
    NY
  6. Mar 16, 2021 at 11:43 AM
    hitech
    hitech New Member
    Blair
    SOMD
    I realize they are different. The point I was trying to make was there are mounting holes on the 19 grill that are not on the 17, so, if the 18 sensor holes line up then you shouldn't have an issue. If they don't line up, you could probably make it work by doing some redneckery to it (southern Marylander, what do you expect.LOL). Good luck and let us know if you get it sorted out, I think there are a lot of Tundra owners who have done it.
  7. Mar 16, 2021 at 12:45 PM
    Lyon
    2018 Tundra Limited
  8. Mar 16, 2021 at 1:08 PM
    timsp8
    NY
    I sucked it up and got the oem one. I didn’t want any issues with the sensor that the dealer would say was my fault.
  9. Mar 16, 2021 at 1:40 PM
    Lyon
    2018 Tundra Limited
    Thanks,I'll do the same and get the oem. I ordered the grill because I thought there was a cheaper option, but oh well.
  10. Mar 16, 2021 at 1:58 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Agreed that the OEM garnish is way overprice, but it's a safety system and a potential liability any time you screw with something in that realm. Having said that, I've had no issues with either of the aftermarket, cheaper alternatives that I've tried over the last year or so. But I'm also not going to recommend anything specific, due to the aforementioned liability ;)
