Question: 120V & 12V outlet(s) on 2022 Limited
Discussion in '3rd Gen Tundras (2022+)' started by GoTTi74, Sep 23, 2022.
  1. Sep 23, 2022 at 4:08 PM
    GoTTi74
    GoTTi74 [OP] New Member
    Bay Area, California
    2022 Tundra Ltd TRD OR CM LB
    Although I was hoping to get a 2022 Limited with the Advanced Power Package (APP), they are barely available here and I'm waiting for a Limited without APP.
    The weird thing is though, that I can't find a reliable information about what comes as standard. I've seen pictures on this forum with Limited having a 120V outlet in the back of the center console and others only have an USB-C. Last weekend I was at a car dealership and the Tundra I looked at (can't remember the trim) neither had a 12V nor 120V outlet anywhere.
    I'd love a 120V outlet to charge our computers while being on the road and if not available use a 12V to 110V inverter. "Last resort" would be to run a cable directly to the battery for an inverter...
    This being said, what did your truck come with in regards to 12V and/or 120V outlet?
  2. Sep 23, 2022 at 5:25 PM
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    My Limited has neither. Can’t imagine why they wouldn’t assume everyone would want that option when it’s less than $400.
  3. Sep 23, 2022 at 5:35 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I believe the rear usb charging ports is standard on limited and above trim models.
    SR5 and SR doesn't have rear usb from what I've seen. I have SR5 TRD Sport premium with advance tech package and I have the 120V 400W inside and in the bed, but no USB charger in rear. Had to buy parts and install it myself. Cost about $50.
    Troyboy84 likes this.
  4. Sep 23, 2022 at 6:17 PM
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    Mine came is equipped with it. It’s listed as LIMITED POWER PKG
  5. Sep 24, 2022 at 9:14 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    I finally got my parts in. $20 for the USB/usb-c piece and I bought 10prs of terminals and plugs. Did you tie in to the front USB power?
  6. Sep 24, 2022 at 9:38 AM
    xc_tc
    xc_tc New Member
    The 12 V cigarette lighter plug is on top of the dash but there’s only one.
    GoTTi74[OP] likes this.
  7. Sep 24, 2022 at 2:53 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    Yeah, I used posi taps into the usb charging port in the arm rest console.
    Rockgate[QUOTED] likes this.
  8. Sep 25, 2022 at 10:53 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Cool. I'm wanting to make these and the fronts constant power. The fuse for it is under the passenger dash.
  9. Oct 1, 2022 at 11:34 AM
    AND
    AND New Member
    Washington, PNW
    Did you ever get this done?
    got any pics or a writeup?
  10. Oct 1, 2022 at 1:51 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    Not yet. I've not had time to get into it. I did pop a panel out to verify there are no wires for the factory power running boards to the left of the steering wheel.
    AND likes this.
  11. Jan 23, 2023 at 12:48 PM
    Beardaho
    Beardaho New Member
    23 Limited TRD LR 6.5
    I have the USB ports to the back seat in my Limited, but really wanted the 120v outlet in the cab and bed. Has anyone successfully added these with factory parts? I did a search and only found this thread specifically centered around adding power options.
  12. Jan 23, 2023 at 1:16 PM
    GoTTi74
    I didn’t see anyone retrofit the whole “Power Package”, meaning switch on the left driver side dash, inverter and outlets in the back console and bed.
    Here’s a post of someone adding an inverter with the factory outlet in the back console.
    https://www.tundras.com/threads/120-volt-inverter-installation.114521/
    Currently, I tend more towards a portable Power Station (e.g. EcoFlow Delta 2) rather than limiting myself to the 100/400W that require the engine to run.
    On our last longer drive, where my wife had to work, we used an inexpensive 500W Pure Sine Inverter connected to the 12v outlet on the dash which was fine. Not great if you have OCD and cables are dangling off the dash but I was focusing on driving anyway…
  13. Jan 23, 2023 at 1:19 PM
    Beardaho
    Beardaho New Member
    Thank you! Of course I just found that thread after the posting my question.
