Quad in bed and trailer camper???
Discussion in '3rd Gen Tundras (2022+)' started by grnwdjsn, Jun 13, 2024.
  1. Jun 13, 2024 at 10:45 AM
    grnwdjsn
    grnwdjsn [OP] New Member
    2023 Tundra Limited TRD Offroad
    Has anyone put a quad in the bed of their 5.5' bed and hauled a camper? I am thinking of buying an extended hitch so that I can hook a 17' camper and haul my small quad to Idaho for a hunt.
  2. Jun 13, 2024 at 10:47 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    Might want to check those payload ratings and combined tongue weight + quad weight + other gear regardless of what others have done. Sounds like you are likely in HD territory.
    LimitedLuck and GODZILLA like this.
  3. Jun 13, 2024 at 10:56 AM
    I thought a set of airbags made all of that possible. Kidding. A 4 wheeler will be 450# or more. So depending on payload, you’ll have that much less available for the tongue weight and people on board. Add another 5-600# tongue weight for a 17’ trailer and you’re pushing it. Could be close on ratings, I suspect you’ll have significant sag in the rear suspension and it will drive poorly. If the numbers work, hook it all up and do a short test drive to check the ride, handling and braking. I’ve put a 4 wheeler in the back of my first gen and towed a 16’ trailer with a side by side on it.
  4. Jun 13, 2024 at 11:06 AM
    grnwdjsn
    Looking at the numbers it is right on the limit maybe a little heavy. 500# quad, 350# tongue, guys, gear etc. is like 1800 - 1900#. I have the TRD Off road suspension, so not much adjusting going on there.
  5. Jun 13, 2024 at 11:19 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Youll be riding those bump stops all the way
  6. Jun 13, 2024 at 11:20 AM
    I doubt you have 1900# of payload. Probably more like 1400-1500# at best
    LimitedLuck likes this.
  7. Jun 13, 2024 at 11:38 AM
    grnwdjsn
    Well the sticker is 1335# so that is way different than I thought. I read 1720 in the specs. That seems so low. 4 dudes and beer will weigh nearly that much. I must be overloading this truck constantly during golf outings...
    Honestly though, I had 18 sheets of 32x80 1.25" particle board in it last month and was not on the bumps. Had about 1.5" of clearance. I only had to go 20 miles though. That was nearly 1750# in the bed. Just me in the cab. It looked like those down south reverse lift jobs!!
  8. Jun 13, 2024 at 11:40 AM
    yup. My 2019 says 1120#. Count your blessings
  9. Jun 13, 2024 at 12:23 PM
    2mchfun
    Trailer toad dolly can take tongue weight off the truck.
    GODZILLA likes this.
  10. Jun 13, 2024 at 2:33 PM
    Bnewman077
    Bnewman077 Happy 2023 Owner
    2023 Tundra TRD OR Lunar Rock
    18” Method Wheels, 35x12.5 Toyo AT3, TRD Pro suspension with Westcott preload lift and Icon rear springs
    I don't know about the specs but that sounds like a good time to me. Pretty sure the truck can handle it
