EEF Qi Charger v2 Release and Dual Charger Sneak Peek…
Discussion in '3rd Gen Tundras (2022+)' started by Front_Range_Pro, Oct 28, 2022.
  1. Oct 28, 2022 at 8:13 PM
    Front_Range_Pro
    Front_Range_Pro [OP] EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    UPDATE: 03-07-2023 (follow @Front_Range_Pro on IG for more updates)
    NOTICE FOR GOOGLE PIXEL 7 PHONE USERS:
    Users of Google’s Pixel 7 and similar models may experience slower charge speeds. This is due to a limitation on charging (by the phone manufacturer) to 12W if using a non-Google wireless charger.
    DUAL CHARGING UNIT JUST HIT PROTOTYPE FORM!
    AS OF 03/20/2023: THE RELEASE DATE FOR THE DUAL CHARGER IS YET TO BE DETERMINED.
    Details to come but here are a couple pics from the initial test fitting:
    FULL PRODUCTION IS IN AND UNITS ARE BEING SHIPPED!
    Head over to https://www.EuropeanEnterprisesFirm.com/ and order yours!
    Product Line (so far):
    • EEF Universal Charging Insert:
      • Designed to fit 2022+ Toyota Tundra WITH factory installed Qi charger.
      • PRICING: $99
    • EEF Universal Charging Insert and Mounting Plate (aka retrofit kit):
      • Designed to fit 2022+ Toyota Tundra WITHOUT factory installed Qi charger
      • PRICING: $159
      • NOTE: if vehicle does NOT have factory-installed Qi charger, an additional part from Toyota is required.(not included):
        • “Box S/A Console FR” (part number: 58802-0C030-C1)
        • See below picture; it’s the plate but without the blue/yellow section
    Lastly, we will always acknowledge the support the Toyota Community (especially the Tundras.com community) has given us. We truly feel extremely appreciative and it definitely makes all this worth it. Thank you all!
    Jonathan
    ABOUT EEF:
    EEF is a veteran-owned Colorado-based company, that I’ve been working with to develop wireless charging solutions for 3rd gen Toyota Tundras and (soon to be) 3rd gen Toyota Tacomas.
    2DD752A0-D40F-4FBE-8480-CFC723D485D7.jpg i
  2. Oct 28, 2022 at 8:27 PM
    Dugnor
    Dugnor New Member
    2022 Tundra 1794 WCP
    Interested, would the apple or Android versions still charge other phones?
  3. Oct 28, 2022 at 9:08 PM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    I would be interested in giving this a try as it becomes available. Looking forward to it!
  4. Oct 28, 2022 at 9:24 PM
    LB-1889
    LB-1889 New Member
    Is this just for trucks that already have a qi charger or will it work with trucks that don’t currently have one from the factory also?
    splashflash likes this.
  5. Oct 28, 2022 at 9:55 PM
    Mls2
    Mls2 New Member
    2019 Toyota Tundra trd pro 4wd
    Cold air intake
    Interested, have 2019 Toyota Tundra Trd pro.
    Joro43 and rockmup like this.
  6. Oct 28, 2022 at 9:57 PM
    deanyuan
    deanyuan New Member
    interested as well.
  7. Oct 28, 2022 at 10:02 PM
    TundraTx12
    TundraTx12 New Member
    2022 Tundra 4x2 SR5 CrewMax
    I have the same question. I would like to add qi charger to my ‘22 SR5 which does not have the factory charger.
  8. Oct 28, 2022 at 10:29 PM
    Donas
    Donas New Member
    TN
    22 Tundra Platinum
    I'm interested, but don't use Apple products.
    I have found the factory charger is very case specific. When I got my 22, the charger worked phenomenally well. It always stayed connected and charged at a reasonable rate for wireless. A few months after getting the truck, I upgraded my phone and changed case style and now the charger is completely useless; my phone won't stay connected for 10 seconds straight.
  9. Oct 29, 2022 at 2:40 AM
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Interested too if its applicable to 2.5 gen as well. 19 PRO
  10. Oct 29, 2022 at 4:08 AM
    Kkwatz
    Kkwatz New Member
    Interested
  11. Oct 29, 2022 at 5:40 AM
    M2Outside
    M2Outside New Member
    2022 Tundra Limited - Magnetic Grey
    Android user here. Super interested to make the charger better for my Pixel 6. Keep us updated!
  12. Oct 29, 2022 at 5:58 AM
    509Yota
    509Yota New Member
    23 TRD Pro MGM
    Interested
  13. Oct 29, 2022 at 6:14 AM
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    Very interested as well for Android Pixel 7. Had a Pixel 6 and with or without a slim case, didn't work. Upgraded to Pixel 7, same issue. My son's older Pixel seems to work ok. Thinking it may be due to the newer Pixels having the protruding camera on the back preventing it from sitting flush on the charger so hopefully a stronger charger resolves it. Please keep that in mind on your redesign. Thanks!!!
    roboots21 likes this.
  14. Oct 29, 2022 at 6:23 AM
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Interested in adding a qi charger for my 22 Limited that didn’t come with the factory charger
  15. Oct 29, 2022 at 8:04 AM
    Lunagas11
    Lunagas11 New Member
    TX
    22 LunarRock TRD PRO
    TRD running boards TRD tonneau cover 35" BFG AT K/O2
    Interested
  16. Oct 29, 2022 at 8:17 AM
    Breathing Borla
    Northern Illinois
    I will likely have my new rig by then and I’ll be interested, I use a 14 pro max with Apple silicone MagSafe case
    if you guys can make the magnet work like MagSafe that would rule
  17. Oct 29, 2022 at 9:08 AM
    RingofScars
    RingofScars New Member
    2022 Tundra Limited
    Interested
  18. Oct 29, 2022 at 10:26 AM
    naddysaad
    naddysaad New Member
    2022 Tundra TRD Pro
    Interested
  19. Oct 29, 2022 at 10:48 AM
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Interestesed. '22 TRD Pro and Pixel 6.
  20. Oct 29, 2022 at 11:46 AM
    Dos Cylindros
    Dos Cylindros New Member
    2022 1794 Edition Smoked Mesquite
    Interested. I will definitely buy one!
  21. Oct 29, 2022 at 12:00 PM
    Front_Range_Pro
    Vail, Colorado
    Thanks for the great feedback so far!
    To clarify, however,
    The first iteration is aimed at Apple iPhone users in the 3rd gen Tundras with the qi option already installed. After that, we can easily make a second version for android/other phone users (which can use generic chargers).
    We are also working on a solution for the non-qi equipped vehicles but that is a little more difficult as the thickness of the panel plastic is a major reason why the wireless charging is ineffective. Once we figure that out, then adding secondary chargers for the right side wouldn’t be that much of a problem either.
    Again, thanks for the positive comments. We are working as fast as we can. Quality and form are both high priorities for us.
  22. Oct 29, 2022 at 12:00 PM
    22PlatWCP
    22PlatWCP New Member
    Mississippi
    2022 WCP Platinum 4x4
    interested...with a question...will you be printing that entire piece shown in the first photo or just the area highlighted where the phone sits?
  23. Oct 29, 2022 at 12:08 PM
    KClav
    KClav MGM Limited
    Maybe for those of us without the factory qi charger we can just get the console insert with the cutout from Toyota and use OP’s solution. I think the part number is
    588020C030C1 but need to verify.
    ryanwgregg likes this.
  24. Oct 29, 2022 at 12:13 PM
    Tundranewcomer
    Tundranewcomer New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    This definitely seems like the easiest solution.
  25. Oct 29, 2022 at 12:29 PM
    SawF16
    SawF16 New Member
    Interested!
  26. Oct 29, 2022 at 1:10 PM
    taschmidt86
    taschmidt86 New Member
    2022 Tundra 1794 W/ TRD Package
    None
    Interested!
  27. Oct 29, 2022 at 1:42 PM
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    Interested! 22 Pro looking for a mag safe option to replace the QI
  28. Oct 29, 2022 at 1:57 PM
    mwt11
    mwt11 New Member
    NC
    2022 White TRD PRO
    Interested, but only for the android version.
    I've had better luck on my Pixel 7 by putting little black sticky rubber bumpers (essentially these https://amzn.to/3STKl3I), like that would go on a kitchen cabinet door, as feet on something that sits on a table, or on the back of a picture frame to BOTH the lip of the platform under the Qi charger, and the left side of the Qi charger (2 in each spot). The ones on the bottom lift the phone 4-5mm and the ones on the left prevent it from sliding to the left while driving.
    For me, it seems like an alignment issue, and lifting the phone slightly as well as preventing it from sliding to the left when I go around a corner quickly, seem to help charging a LOT. I do not use a case on my phone.
    My plan is to eventually 3D print a part that would do this by lifting the phone and has a little tab (like is already on the right side of the Qi charger) on the left side to prevent the phone from sliding around. I'd probably need to print a new one every time I got a new phone though.
  29. Oct 29, 2022 at 2:57 PM
    1794ELPTX
    1794ELPTX 2022 1794 Edition Tundra
    El Paso, TX
    2022 1794 Tundra
    Please add me to the list of interested buyers.
  30. Oct 29, 2022 at 2:58 PM
    matgor
    matgor New Member
    On Order 2022 lunar rock Limited
    Interested
