Putting more aggressive tires on stock 20's
Discussion in 'Wheels & Tires' started by JohnRuck1985, Apr 3, 2018.
  1. Apr 3, 2018 at 7:16 PM
    JohnRuck1985
    JohnRuck1985 [OP] New Member
    Good afternoon, I recently purchased a 2018 limited crew max and it came with stock 20 inch rims. In the contract, I got the dealership to include color matched pocketed fender flares on the truck which will be in later this week.
    I'm worried that it will look bad with the stock rims and tires and I want a more aggressive look. Can I take the wheels off and throw some 285/60r20s on it after my billstein 5100 level kit?
    I attached a picture of the truck, suggestions?
  2. Apr 3, 2018 at 7:49 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I'd say you can. My truck is a 2017 SR5 double cab 2wd. I'm running 285/55r20 BFG ko2's. No rubbing anywhere at anytime.
  3. Apr 3, 2018 at 7:58 PM
    easleycrawler
    Travis
    My truck is stock. No lift or leveling kit.
  4. Apr 3, 2018 at 8:13 PM
    JohnRuck1985
    looks great! I almost feel like I should even go bigger than that. Like a wider tire to fill the wheel well more
  5. Apr 3, 2018 at 8:30 PM
    easleycrawler
    Travis
    285's fill them pretty good.
  6. Apr 14, 2018 at 2:14 PM
    tt2323
    tt2323 New Member
    2018 White Platinum crewmax
    I was looking to do something similar. 20” stock rim and a more aggressive tire with perhaps a leveling kit. Curious to know what you decide.
  7. Apr 17, 2018 at 11:46 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    You definitely can! I think those stock 20's look sharp, and I for sure would throw some nice tires on to compliment the look. If you are going with the leveling kit, there are quite a few sizes you can run depending on the tire you want. I would look at the ones you mentioned, 275/60/20 as well as others.
  8. Apr 17, 2018 at 12:34 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You're still going to be tucked in quite a bit with the flares. I would look into some wheel spacers or new wheels with a lower offset.
    NewImprovedRon and Boerseun like this.
  9. May 1, 2018 at 7:45 PM
    Jbl1033
    Jbl1033 Uemgawa
    Aubrey TX
    2022 Tundra 1794 Smoked
    Westcott level bronze KMC 20”x 35 Nitto Grapper
    Here’s my level ‘17 Limited stock rims powder coated & Toyo m/t
    heidson, Navi, Patriot and 2 others like this.
  10. May 1, 2018 at 7:47 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    How's the road noise compared to the original set?
  11. May 1, 2018 at 7:49 PM
    Jbl1033
    Jbl1033 Uemgawa
    Aubrey TX
    Nada but as tires wear it’ll increase noise so just turn up the tunes lol
    nk1794[QUOTED] likes this.
  12. May 1, 2018 at 8:01 PM
    1794TRD
    1794TRD It is, what it is!
    Little Rock, AR
    2015 Super White II TUNDRA 1794
    TRD EXHAUST TRD INTAKE Lift 3” front 1.5” rear TRD SKIDPLATE UNIFLEX TRIFOLD BED COVER UNIFLEX SWINGBOX POP & LOCK POWER TAILGATE LOCK TUNDRA BED LIGHTS LED HEADLIGHTS / FOG LIGHTS / PUDDLE LIGHTS / INTERIOR LIGHTS WHITE DOOR HANDLES WHITE MIRROR COVERS TOYTEC BOSS REAR SHOCKS CRUX AVITY-01 VIDEO INTERFACE AJT KEY FOB COVER
    Did you mean to say TOYO R/T? Those are not M/T’s you have there.
  13. May 1, 2018 at 8:41 PM
    417Tundra
    417Tundra New Member
    Levi
    2013 platinum
    305/55/20 Toyo A/T Open Country Xtreme
  14. May 2, 2018 at 5:35 AM
    Jbl1033
    Jbl1033 Uemgawa
    Aubrey TX
    Gasp, you sir are correct. Toyo R/T LT285/60R20
  15. May 9, 2018 at 4:45 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I put 295 55 20 toyo RT on my factory tss wheels after a bilstein 5100 level. The driver front tire rubbed the "skid plate" once. I bent it up and haven't rubbed since.
  16. May 9, 2018 at 4:53 AM
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    Pics??????
  17. May 9, 2018 at 5:15 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I'll get a better one when I get to work.
    Mr_Kane and OceanSkyWolf[QUOTED] like this.
  18. May 9, 2018 at 5:17 AM
    OceanSkyWolf
    2017 MGM CM
    That’s BA!
  19. May 9, 2018 at 5:20 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Thanks. I like it.
  20. May 9, 2018 at 5:53 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    20180509_074151.jpg 20180509_074142.jpg 20180509_074132.jpg 20180509_074121.jpg
    OceanSkyWolf[QUOTED] likes this.
  21. May 13, 2018 at 3:56 PM
    JCTundra2323
    JCTundra2323 New Member
    2018 Toyota Tundra TRD
    33” Nitto ridge grapplers on 20”/12” fuel coupler +20 offset 2 1/2 front level Running boards
    Is that a 3 inch leveling kit?
  22. May 13, 2018 at 4:08 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    If you are asking me, I have 4 bilstein 5100s. Front on top setting so like 2.25" and an add a leaf in rear.
  23. May 13, 2018 at 4:12 PM
    JCTundra2323
    Gotcha thanks. I want to get the 3 inch leveling kit and new rims a 33 inch tires. I am sorting through all the million brands do you have any recommendation?
  24. May 13, 2018 at 4:17 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I have 295 55 20 toyo open country rt tires. These were the largest that I could do on my factory wheels without rubbing. That said they are almost 33" tall and about 12" wide. I've only put about 300 miles on them so far. Hard to give a good opinion yet, but they are pretty quiet considering they are mildly agressive.
    I chose these over the ridge grapplers because they were about $50/tire cheaper through my dealer.
    Scortow likes this.
  25. May 13, 2018 at 4:21 PM
    JCTundra2323
  26. May 13, 2018 at 4:27 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
  27. May 13, 2018 at 4:29 PM
    JCTundra2323
    @Hondoman Alright thanks for all the info, I am learning about all this stuff for the first time. I literally have been searching and looking for a month and still feel kind of lost trying to decide on what to get.
    Hondoman likes this.
  28. May 13, 2018 at 4:31 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Haha, take your time and find a setup that you really like. Don't compromise.
  29. May 13, 2018 at 4:32 PM
    JCTundra2323
  30. May 14, 2018 at 1:45 PM
    JCTundra2323
    @Hondoman I forgot to ask how loud and smooth the ride is with your set up
