Purchase Question- New Rear Axle at 8,500 mi
Discussion in '2.5 Gen Tundras (2014-2021)' started by TNtundra22, Mar 19, 2024.
  1. Mar 19, 2024 at 6:11 AM
    TNtundra22
    TNtundra22 [OP] New Member
    Looking at a 2019 with 17,000 mi, saw this on the service history? Seems odd to have had that work done with such low mileage. Would that cause you to pass on it? I guess on the plus side it was done at the dealer and is all new, but still.
    DIFF.CASE SUBASY-T.RING GEAR ~|~CUSTOMER STATES HEARING RUBBING NOISE FROM REAREND WHEN APPLYING BRAKES SLOWING TO A STOP - CHECK REAR AXLE RUNOUT ~|~CONFIRMED NOISE, CHECKED REAR ROTORS AND FOUND RUNOUT ON ROTORS, CHECKED HUBS, FOUND RUNOUT ON HUBS, HUB RUNOUT LIKELY CAUSED ROTORS TO HOTSPOT, CAUSING RUNOUT ON ROTOR NEEDS ROTORS TURNED AND AXLES REPLACED ON REAR UPPON REMOVAL OF AXLES, FOUND METAL FR ~|~REPLACED WHOLE REAR END, INCLUDING CARRIER ASSY AND AXLES
  2. Mar 19, 2024 at 6:22 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Not necessarily imo. New axle means no more headaches experienced from the PO. Could've been a bum axle from the factory - they sold over 100k Tundras in 2019 just in the States so a lemon axle here and there wouldn't be outside the realm of possibility.
  3. Mar 19, 2024 at 7:57 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I would drive it make sure there's no other issues or noises. That's low miles for a 2019. Hopefully someone wasn't chasing gremlins and decided to just trade in. If everything checks out, I don't think it's a cause to pass on it.
    TNtundra22[OP] likes this.
  4. Mar 19, 2024 at 8:38 AM
    clownkillerloaf
    clownkillerloaf New Member
    Logan
    '21 SR 5.7
    wouldn't worry me at all. Warranty issue, and they took care of it. These axles are ancient tech, pretty much bulletproof.
  5. Mar 19, 2024 at 5:20 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I agree. It’s a good sign the driver noticed and took it in ahead of actual failure.
  6. Mar 19, 2024 at 5:51 PM
    d33pt
    d33pt New Member
    I wouldn't worry about it either. That means it's all new stuff in the rear end. It's not like it's a new engine or transmission at 8k. I'd probably pass if it was that.
