Pulling.
Discussion in 'Towing & Hauling' started by Tundra camper16, Sep 8, 2019.
  1. Sep 8, 2019 at 4:18 PM
    Tundra camper16
    Tundra camper16 [OP] New Member
    2016 5.7 tundra long bed
    Does anyone pull a 5th wheel with a 2016 Long bed?
    OR18TRD likes this.
  2. Sep 8, 2019 at 4:26 PM
    Mnorris1206
    08 tundra
    Cheers to the long bed part. Idk if anyone here does but I can tell you that the original owner of my 08 long bed did. The hitch was in the bed when I bought it and the rails are still there . I already had a bumper pull camper so I didnt look into it to much
  3. Sep 8, 2019 at 4:41 PM
    Tundra camper16
    Thank you for the information hope more respond with good results love long Beds
    Mnorris1206 likes this.
  4. Sep 8, 2019 at 4:54 PM
    Mnorris1206
    08 tundra
    Blueknights75, 15whtrd and jeremyd like this.
  5. Sep 8, 2019 at 4:56 PM
    Mnorris1206
    08 tundra
  6. Sep 9, 2019 at 7:58 PM
    Tundra camper16
    Love the tired I posted a pic of my long bed before tinted windows , running boards and bed cover
  7. Sep 9, 2019 at 7:59 PM
    Tundra camper16
  8. Sep 10, 2019 at 6:22 AM
    Check out the towing section. Lots of good information on this topic.
    Short answer, for most 5th wheel campers, the pin weight is over the capacity of the Tundra. Some camper manufacturers make light weight 5th wheels.....
    15whtrd and Trooper2 like this.
  9. Sep 10, 2019 at 6:42 AM
    Tundra camper16
    Thank you for the info. We found out that indesign has a 150 series 5th wheel that starting weight is 7000 very light for a 5th wheel. Still researching.
  10. Sep 10, 2019 at 6:54 AM
    Mnorris1206
    08 tundra
    This has always been my question how much weight can we put in the bed or how much pin weight will it take.
  11. Sep 10, 2019 at 7:27 AM
    Look inside your drivers door. It will tell you all the information you need.
    Mnorris1206[QUOTED] likes this.
  12. Sep 11, 2019 at 5:08 AM
    00PS
    00PS New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    Pulling is typically not the issue, it is how much (or little) the truck has for payload (I.e. when you hook up the trailer, the weight that is now resting on the truck). This is usually 1,100 to 1,400lbs depending on your trucks configuration. Available payload for a trailer will decrease when/if you add passengers, mods, supplies and/or other gear in the bed.
  13. Sep 11, 2019 at 5:24 AM
    Tundra camper16
    Thank you great information
  14. Oct 9, 2019 at 7:40 PM
    Sp33dNut
    Sp33dNut New Member
    2019 White Tundra DCOR
    The other thing to consider is that the amount of weight in the bed will increase when the wind pushes the front of the 5er down while going down the road.
  15. Oct 10, 2019 at 4:23 AM
    Tundra camper16
    Thank you for this information.
