Puddle light and signal wiring at mirror plug?
Discussion in 'Lighting' started by Tundra234, Jan 27, 2021.
  1. Jan 27, 2021 at 2:29 PM
    Tundra234 [OP] New Member
    Does anyone know if there is puddle light wiring and turn signal wiring at the mirror connector on the door without having to run wiring all the way down to the kick panel? This is for a 2020 SR5. Thanks
  2. Jan 27, 2021 at 2:31 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Turn signal pre wiring is likely, puddle lights are more of a gamble.
  3. Jan 27, 2021 at 2:34 PM
    Gotcha. I don't mind running wire, I did it on my 2013. Just trying for cleaner installs on the 2020. I'm putting the VLeds puddle lights in.
    panicman and Wynnded[QUOTED] like this.
  4. Jan 27, 2021 at 2:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I would say that the fastest way to determine what your truck is pre wired for would be to plug the mirrors in and see what works. Then you'll know what may need to be done. My 2011 SR5 was wired for the signals/heat/adjustment. When I upgraded them I had to wire for light/fold/auto darkening. There's little chance of correctly guessing what Toyota has changed since then.
  5. Jan 27, 2021 at 3:05 PM
    I have the Muth signal mirrors that I will be putting in. Yeah Toyota is crazy.....they changed the radio connectors and wiring on the 2020's. Alot of stuff is different. For example, I put in AutoLocs for the windows using a video from @2020Platinum. Both of our trucks are 2020's, but my wire colors on my SR5 are different than his Platinum. :notsure:
    2020Platinum and Wynnded[QUOTED] like this.
